Tanix TX5 Max Amlogic 905X2 4/32gb Dual Wifi Lan BT4
Hi
I hope I'll get some advice here
I want to watch IPTV using this device, unfortunately the app says that it detected root and won't let me see (the playback is blocked due the root was detection)
Tried to use magisk - didn't work after installation i had a boot loop so i had to burn stock firmware again
any suggestions?
Latest Sasvlad build, i faced strange issue. Sometimes screen becoming screen for a second and turning back normal
This worked for me , as per developer black screen is intended feature.
I want to watch IPTV using this device, unfortunately the app says that it detected root ..............
If u wnt to stick to official firmware
Try using xposed with Root Cloak application.
On my box magisk works fine. Did u install using Magisk installer or zip flash. I recommend installer apk first or simply use xposed installer apkLast edited by usernamereg; 08 April 2019, 06:27.
Originally posted by usernamereg View Post
Go to Amlogic tool apk and " in the AFRD tab in the Amlogic Tool program. Recovery to default can be turned off altogether"
Originally posted by tedpoley View PostCan anyone please provide me with Sasvlads custom rom? Can't download it from 4pda.ru. Want to try it on my X96Max.
The stock rom for Tanix Tx5 is not activated and I don't know how to do it.
dude I think u screwed you device MAC Id code synchronization with the device ID. Flashing new RoM wont help. I had same issue
you will have to reflash the box using usb tool and while doing so u have to check "whether overwite key" option. Try this link
https://4pda.ru/forum/index.php?show...ost&p=82266882
credit surkov.alex
Originally posted by manu4024 View PostHi guys, install JY-TX5Max-NavigationBar-20190221 firmware and I have problems with bluetooth, I can not send files and when I connect some speakers it disconnects at all times. have you had the same problem?. Apologies for my bad English
Edit : Already tested it for a while. I was able to transfer a file from the box to my phone, with ES file explorer.
As for the Bluetooth speakers, i used it for more than an hour and had only 1 disconnect.
How often do you get disconnects?
Originally posted by TheBlackening View Post
I haven't tried the bluetooth yet. I'll try it later today and I'll report back here.
frequency: 2.4
I realized that having Bluetooth and Wi-Fi enabled, the bluetooth works very badly, it disconnects completely. So I decided to open the box and my surprise was to find another wifi / bluetooth chip different from the one that was previously published here and in other forums such as 4pa. Could that make the problem in all this?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2918 users online. 0 members and 2918 guests.
