Announcing the release of Complete PicUntu 4.4 Distribution
upgrade ?
Originally posted by aloksinha2001 View PostThe previous state is remembered by the system.
Do delete all previous network ports.
Code:vi /etc/udev/rules.d/70-persistent-net.rules
Oh and to not do the step ove - I have to release a small minor upgrade.. in the meanwhile.
vi /etc/rc.local
Add a line
insmod /lib/modules/rkwifi.ko
( a tmp solution, till I get you the minor version upgrade)
Alok
Problem with extracting files on sdcard
This is a great work and I want to see this working on my device.
But, I have problem with extracting files on sdcard.
I give command as root: tar -xzf skeleton.tgz(or bazicgui.tgz) -C /media/linuxroot .... and after a while ..... say about 1 minute ... I receive a lot of tar erors: cannot stat or read-only file system. I tried that with my installed Ubuntu 10.04, live Ubuntu 10.04 and live 13.04 (with sudo -i of course). I obtain the same error messages. After running command I have a lot of folders and files on sdcard, but, I think that not all files had been copied.
I tried this on two sdcards formatted ext4 with gparted... the same errors.
Is my laptop card reader broken?
Any idea?
Thank you.
Edited after:
It seems that my sdcard reader has problems with mini sd adaptor card. I had miniSD card with adaptor. After put card in usb sdcard reader, I had no errors.
But still cannot enter picuntu. Box freezes when I enter recovery mode.Last edited by adrianio; 03 November 2013, 10:56.
Installed on Cozyswan MK822 - RK3188, Mali, ap6210 wireless, BOX
- I installed ap6210_after7iul13 kernel in recovery partition and basic gui on sdcard. It looks good. Thanks for your work.
I have following problems:
1. hundreds of syslog errors about flash reading:
Code:[<c062da68>] (unwind_backtrace+0x0/0xe0) from [<bf009784>] (FlashReadErrorDump+0xb0/0xe4 [rk30xxnand_ko]) [<bf009784>] (FlashReadErrorDump+0xb0/0xe4 [rk30xxnand_ko]) from [<bf00af70>] (FlashReadEnhanced+0x238/0x270 [rk30xxnand_ko]) [<bf00af70>] (FlashReadEnhanced+0x238/0x270 [rk30xxnand_ko]) from [<bf00c1a8>] (ReloadFlashInfo+0x4c/0x110 [rk30xxnand_ko]) [<bf00c1a8>] (ReloadFlashInfo+0x4c/0x110 [rk30xxnand_ko]) from [<bf016034>] (FlashInit+0xbf8/0xed0 [rk30xxnand_ko]) [<bf016034>] (FlashInit+0xbf8/0xed0 [rk30xxnand_ko]) from [<bf016388>] (FtlInit+0x7c/0x158 [rk30xxnand_ko]) [<bf016388>] (FtlInit+0x7c/0x158 [rk30xxnand_ko]) from [<bf0165f8>] (NandInit+0x194/0x330 [rk30xxnand_ko]) [<bf0165f8>] (NandInit+0x194/0x330 [rk30xxnand_ko]) from [<bf016804>] (rk29nand_probe+0x70/0x210 [rk30xxnand_ko]) [<bf016804>] (rk29nand_probe+0x70/0x210 [rk30xxnand_ko]) from [<c06235f4>] (do_one_initcall+0x90/0x160) [<c06235f4>] (do_one_initcall+0x90/0x160) from [<c0688450>] (sys_init_module+0x1698/0x1828) [<c0688450>] (sys_init_module+0x1698/0x1828) from [<c0628ac0>] (ret_fast_syscall+0x0/0x30) ATime: 38 ns AHB: 148 timming: 1081 FlashReadRetry error!!,row = 20f60 data:14 47 79 6b 92 ef 19 b3 22 f9 71 45 c7 b2 80 d6 ATime: 44 ns AHB: 148 timming: 1082 FlashReadRetry error!!,row = 20f60 data:14 47 79 6b 92 ef 19 b3 22 f9 71 45 c7 b2 80 d6 ATime: 32 ns AHB: 148 timming: 1061 FlashReadRetry error!!,row = 207e0 data:0f a5 2e af 42 e2 2c 25 2a 0d 02 98 be 98 cb a4 ATime: 38 ns AHB: 148 timming: 1081 FlashReadRetry error!!,row = 207e0 data:0f a5 2e af 42 e2 2c 25 2a 0d 02 98 be 98 cb a4
ifconfig show only eth0 and loop.
3. I cannot wake up eth0 (ifconfig show it).
Command "service networking restart" freezes at "networking stop/waiting".
In syslog:
Code:usb 2-1.2: new full speed USB device number 4 using usb20_host usb 2-1.2: New USB device found, idVendor=0fe6, idProduct=9700 usb 2-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0 usb 2-1.2: Product: USB 2.0 10/100M Ethernet Adaptor
I could not find to run script picuntu-da-server.sh.Last edited by adrianio; 06 November 2013, 10:17.
XBMC Won't Run on Rikomagic MK802 IV LE (Linux Edition)
Originally posted by opengl1971 View PostSo if mali 400 hw doesn't work i think the XBMC HW aceleration doesn't work right?
--rj
The latest versions of Picuntu and Linuxiumone are working very well. No doubt you will continue improving and soon I will be able to get rid of Android on my PC Stick.
Thank you very much for your great work.
There are currently 1772 users online. 0 members and 1772 guests.
