[ROM] POISONATV S905X NEW V3 [20190307]
Originally posted by k32 View Post
I don't think your box is dead but you flashed an incorrect firmwre and you need to use usb burning tool to flash again this rom or another one.
However, I cannot install any apps because Google playstore hangs on "install pending"
I've gone to settings/apps and cleared the data....but it's still not working.... tried many times.
Is there other ways I can install an app ?...eg: I have Kodi.apk
Originally posted by k32 View PostI download apps I need, from apkmirror and install them from usb stick or use aptoide and alternative for the Google Store.
But there is NO file manager on POISONATV to execute the apk for installing.
How do you install them from usb stick?
Originally posted by k32 View PostWhen I installed my rom, there was a file manager, I used it to browse to my apk on usb stick, then installed them... Just browse to /setting/apps and you will certainly find it !
I would appreciate if very much if you can look at your /settings/apps and tell me exact name of file manager
Then I can look for it...and if I haven't got it, what other options are there?
Originally posted by k32 View PostThe name of the package installed with the rom on my A95X is "com.android.documentsui" it is named "Fichiers" in my french setting means "Files".
I do not have "com.android.documentsui"
That is why i'm having all these problems.
If Google Playstore is fixed, then I will have no problems...but at the moment, cannot do anything.
Originally posted by soldiaz View Post
Go to settings》more settings》Storage
you can then Browse Storage and install.
But when I clicked on it, does not open, cannot browse for files.
Thanks for helping.
However, after a lot of playing around, I have got an app called "Files" as k32 mentioned.
My USB stick is listed...and I can browse files
But when I click on APK file it does not install....it puts a green tick next to filename, can only copy or move or rename.
So I copied the APK to the /Files/Download folder to see what happens....and then it installed when I clicked on it.
This is a strange way of doing it...but it works...and all is good now.
Thanks to all for helping.
There are currently 2437 users online. 5 members and 2432 guests.
