I tried to burn 1 of these ATV (poison and ATV Experience) on my M16 box to no avail using both method; the SD card one starts loading but doesn't progress at all and the USB/PC method fails at 7%.
I tried different USB cables and SD cards to no avail.
I tried an M16 image and it loaded properly.
I think this image isn't compatible with my box even though it's s905x as well.
Is there any guide you recommend reading on what files should I replace on this image to make it compatible? Or is here a specific that most likely caused this issue?
How do I enable the logs to find out what exact action failed?
I do have the original image, so I should be able to move files between the 2 if that's what's needed
TIA
