Beelink GTKing Amlogic S922X 4/64GB Dual AC WiFi-MIMI GiG Lan BT4.2
    I got my box today, but first impression was not so good.
    Installed youtube and also vanced youtube, but in the 2 apps the same, very poor quality, cannot understand this...??
    When i click the quality icon (3 points) there is automatical level always with 480 and when i go to the 1080 (which is the highest that is shown???) i got pixels in the clip
    and when i load a 4K video there is also 1080 the highest to choose...
    Anybody else got this problem? with my broken Mecool i could see also the 4K videos.
      Are you connected with Wi-Fi or ethernet? What are your usage for that box?
        i am connected with ethernet, about 90 MB/s download speed.
        The speed is not the problem, i use the same connection as with my old Mecool (S912) and also the same TV - but there i could choose until 4 k in Youtube clips. Don't understand this.
        My usage is Kodi, Film-tools, Sat-IP etc. this all works normally
        But i cannot understand why Youtube is so limited in quality with so such high hardware values of this box...???
          My GT King with faster S922X-B chip...
            I have been using Superceleron's ATV port, then using Sasvlad's ATV port. All the YouTube 4k videos play perfectly. But there is not frame rate switching. I also dual boot with CoreELEC and the 4k video files play perfectly, even automatic frame rate switching works great.....
            I don't recall how YouTube played with the stock firmware.
            Edit: I did some more investigating of YouTube running under CoreELEC and it will ONLY play in 720p. I have to use the Kodi overlayment code to see what it is actually playing............. Visually, it looks good, even thought it is only playing in 720p.
              Wow! I thought the bigs were running Below 2ghz? Seems way fast enough for FT TYPICAL USERS.
              Yur Not overclocked, huh?
              btw: googly YuTube is supposed to be non-detected by vance, and visa-versa I hear.
              You have the "micro-G" app key loaded, and ck'd yur through-put of streamed data?
              Yur on the nonRoot vance? ...just curious
                This box comes with the new chip Amlogic A311D/S922X-B, faster and better.
                All the GT King boxes with S/N B922 come with this chip.
                    Problem with youtube solved using smart tube app!
                      strange, very strange... that has to be the solution. hmmm?
                        I'd be interested to see a confirmed a311d device, my understanding is that is not a variant in the king. Can you point to an authoritative post for confirmation?
                        ed: though that would explain the higher clock speed, perhaps
                          My GT King B922 with the faster S922X-B processor brings a different board with a ISOCOM chip!!!
                          See photo
                            Just curious, what is it faster and better than? And are the AnTuTu scores any faster and better ? Thanks.
                              20% faster cpu
                              And read this link: https://www.cnx-software.com/2019/07...ideo-decoding/ Click image for larger version  Name:	Screenshot_20190810-130518_Chrome.jpg Views:	0 Size:	71.7 KB ID:	780743
                                Still, NO 311 in the king. There will be no free soc upgrades by breaklink I assure you.
                                ...and the two chips DO differ. Besides, who cares about 4 to 8k output when the actual source media is either extremely limited, or non-existent.
                                Upscaling doesn't count for much, just splitting hairs....
                                Methinks?
