Beelink GTKing Amlogic S922X 4/64GB Dual AC WiFi-MIMI GiG Lan BT4.2
    Have you tried the Coreelec N2 image to see if it works on the King?
    I have not tried it, thought about trying it. They said on their link, that it could possibly brick this box........... So, I was not sure I wanted to try it, at this point in time.
    Edit: I went ahead and downloaded the CoreELEC image for this ** KING ** box, and created a bootable microSD card. From the Beelink GT-King Android OS, I used a terminal emulator to "reboot update" into the bootloader. The CoreELEC would NOT load. There are 3 different device trees for the Odroid N, but none of those device trees would work on this device...............
      Originally posted by bergamesk View Post
      "As usual"
      Or another "Disappointment" Box as usual!
      well all of your comments,that means "sound is not good"! for me
      "S922X" might be for some actions good or very good etc., but who care if the Box has bad or mediocre etc., we have to look at
      the ROM !!
      Seems need lot of bug-fixes and more...
      My Box still in Post Office due to custom clearance purposes as this takes more time here in Turkey
      and expecting delivery time next week!
      After all those reviews/comments;I do not open and use this Box and I put on my Sale list "as usual"
      And wanna give a new order for AM6 by UGOOS
      Their release time around JULY begin or late I do not know!
      I'v contacted with Ugoos Co.(Dear Nancy)
      Seems that before mass production; firmware still not ready!
      Note;I told her KODI; 4K Streams+Video files ""Colour Washed-out"" issue two times;and I said that pls check it!!
      This is unacceptable problem!!
      Seems VC-1 does not support WTF
      Note;
      Hey Clark will you pls check KODI 4K Stream+Videos>>>colour washed-out????
      Thanks and bye++
      I also fought with the issue of the colors being ** washed ** on some of my boxes running on my Samsung 4k TV. I found out that my TV does NOT support HDR. The settings on most of my boxes, has the "SDR to HDR" enabled. When this option is enabled, the colors are ** washed ** out. So, check that setting that is located under "Display".
      • trebor
        trebor commented
        Editing a comment
        Does the Basic media player that is installed on the box Play files as required, my Sony 4k had no issues and color was excellent
        Regarding Plex I am finding even on my SONY TV it is having trouble finding all Drives/files so something gone a bit off with plex.
      trebor. I have to disable the SDR to HDR in the settings, or the colors are washed out. I have the same issue on my Nvidia Shield, I have to disable that option also....... So, it is specific to my Samsung 4k TV.
        Can you see any" benefits"using beelink vs nvidia?
          There is none, zilch, nada......... only good for tinkering and frustration.......... Beelink sent it to me for testing........
            But I don't know why all is"silent "about media player possibilities on new Amlogic s905x2 ,s922 vs Amlogic s905x s912.What about deintelacing I didn't read any post about interlaced video ,This is early stage but I think maybe Amlogic needs some .....time
              This Comment was found and sorta has a point I feel
              It is wrong to immediately jump to a comparison between the King and the Shield. Amlogic made the new S922X SoC compete with Rockchip RK3399, Allwinner, Realtek, and Himedia(the HiSilicon brand for this segment). And mission accomplished, the chip outperforms its main competition in practically every category.
              The fact that the device is limited to 32-bit mode reflects negatively back on Amlogic. They create a base Android 9.0 SDK for their chips which is protected proprietary software and leave it to the manufacturer's and developers to generate the appropriate binaries and libraries to optimize the system. In this case, Beelink went with 32-bit mode to limit the bugs and limit their in-house developmental time.
              To sum up my rant, I agree that this box is overpriced still yet. A price point at $90 to $100 would be more ideal and only then would I consider buying one of these to tinker with. Wait for 6 to 8 months and see what other manufacturers and developers can do to generate more performance and optimize the OS for this chipset.
              @ETA_PRIME good review very much enjoys your channel. Cheers mate.
                Hi ,
                dont know it already known : new Rom ???
                greetings / gefattern
                I'm laughing
                am I??
                KING,look at the model name "King"!
                For whats King
                I love those Chines
                Again make chat with Ugoos as usual!
                They are not ready yet! at least seems that 2/3 months delayed first May than June now July ......well August or
                Sept. its not come to not surprise
                BTW My Box cleared from the Customs but its delivered until 10/12June due to our local Religious long holiday season
                Therefore I'v opened a Sale item list for this King(in our Local Internet Shop) and I'll sale it immy without opened the Box!
                And get to waiting AM6!!
                Weather is extremely high right now Beach Time guys +Beer Time
                  Can you paint on points, is it the new s922 better than 912 or Amlogic s905x (android 6,7) from your point of view?1)faster ,2)USB 3.0 better GPU,better performance but what about video reproduction...is it on same lvl or maybe down in this early stage ....Or maybe king (s922) is better vs hisilicon ,realtek .For now I think is not on same lvl is not better (media player)I hope Amlogic will improve with time and for 6-7 months can be better I rly hope
                    I'm just confuse with those AMLogic toys!
                    Faster;OK try it and see it A95X MAX(kinda super fast! and I'm not sure 922 more faster?? or is it)
                    well at least these Boxes "fast" and is it finished everything?? sure nope
                    Such RK3399 even very fast too or a little bit then 922 but this RK3399 give you very good picture quality! better then any AML(I do not
                    know 922 and I guess 3399 still more better then 922)
                    But 3399 worst ROM/FW etc., support sucks etc.,
                    "KHADAS";my request list number one,probably I'll buy one soon
                      Hey Guys. i'm written on beelink forum that the inside the beelink king exist second microphone wich works all the time. When you disconecting remote control with voice, tv box still listening you.
                      http://www.bee-link.com/forum.php/fo...extra=page%3D1
                      With kind regards
                      YouTube channel TECHNOZON
                      youtube.com/zorronder
                        Hell, I can't even get the stock remote to listen to me.
                          A second microphone Stereo recording cool
                          All Russian to me...i will drink some more Vodka to see if i can find the spot that it mentions
                            Try to hold the button when speaking
                            With kind regards
