CX803 rk3066 New stock Rom 4.2
    yes.. i think tha su is no good for 4.2.2.
    in my "roms" root work... and i thinks that i use file of ila.... but no sure...
    wait new release for test...
      Re: CX803 rk3066 New stock Rom 4.2
      Try also a symlink to sun from bin.
      900Supersport
      freaktab developer
        Or I put a copy of su into bin . :-)
        JDfense
          Okay, next trial. You teach me and I will to cook this ROM.
          Here comes the system.img with lharambr files.
          Download
          JDfense
            The system is not a binary file and SU Supersu can not update it.
            The problem of access
            The system does not see it.
            Maybe in 4.2.2 need other way. /system/xbin/su?
              Root.
              Superuser.apk system\app
              system \ bin \.ext .su
              system \ bin su binary is deleted
              system \ xbin su
              .ext.zip
              su.zip
                I see the /bin/.ext/.su. Have you tried it kent and does it work with this invisible .su file in bin/.ext.
                Anyway I try it tomorrow again.
                JDfense
                  sorry.... but jdefense.. if you download my rom edited first time... in this release root work... you can take superuser, su and busybox from here....
                    Thx angelobiz. I try it, when another option I have will fail.
                    JDfense
                      Next trial.
                      This time I put in koush superuser.apk with the fitting su file, the wanted ultra explorer and petrus rebooter.
                      I hope, this will work, because I'm running out of ideas.
                      Download
                      You could rename the system file to system.img.
                      JDfense
                        system \ bin \.ext \.su no?
                        system \ bin su there is .Why?
                        Root not.
                        Everything else works. Need a Root.We sure can get Root yourself, but it's weird.
                          Okay, lharambr I try to put that bin/.ext/.su in, but I'm not sure, if this would really help.
                          JDfense
                            JDfense
                            bin/.ext/.su That is, in systems.img 4.2.2 Finless,example mk808b
                              Moin JDfense.
                              Maybe it helps you further
                                Yes, but I tried that at the beginning.
                                Right now I'm uploading the system with /bin/.ext/.su again.
                                Then we see..
                                I have checked the boot.img, but there is no reason to find, why root does not work.
                                JDfense
