CX803 rk3066 New stock Rom 4.2
    i test the last version:
    installation work
    microphone: not present
    AUDIO: work (sorry but before my tv was crazy)
    wireless: ok, work
    usb ethernet: ops... i no have usb card now for test :-P
    multiuser: present, but no work
    root: work
    network location: work ( goggle maps work good)
    google market: work
    flash: work
    i would like have:
    microphone
    screenshot
    multiuser ( for a android tv is very important)
    ethernet usb ( in old finless ok)
    webcam usb ( in old finless ok)
    in my best dream:
    external bluetooth
    for now antuto make this: 10726
    thanks a lot!
      microphone?
      Try this http://yadi.sk/d/RPN_GdJXCKpVM
        installation work
        wireless: ok, work
        root: work
        google market: work
        flash: work
        i would like have:
        microphone
        screenshot
        in my best dream:
        external bluetooth
        thanks a lot!
        Hi angelobiz,
        thx for the report and 10726 antutus is for an rk3066 ROM not bad.
        I'm about to release my version 1.0 in the next hour. After that we will see in the next step, which feature(s) we could possible add.
        The backup step, lharambr mentioned is a very useful feature, too.
        JDfense
          Originally posted by Iharambr View Post
          microphone?
          Yes, another kernel could be the clue for the microphone. Let me know, if you find a working kernel.
          JDfense
            JDfense
            working, verified
            multiplayer works
            However, the frequency CPU min and max 1008 and greater heat
              The ROM is released. Thx so far.
              Overclocking is risky without extra cooling. So be careful with the kernel to protect your device as long you have no information, what is changed in the kernel.
              JDfense
                tomorrow i try the kernel...
                but we can cut overclock by kernel?
                if microphone and multiuser work... JD you must study this kernel :-)
                i like do it... but i don't be able :-P
                  multiplayer still refused to work
                  CPU min and max 1008 it is safe
                  I took the kernel from here http://yadi.sk/d/2tThUm-JCDXf6
                    Then check the kernel angelobiz and keep the heat under control
                    JDfense
                      Term.apk need to make the user/system/preinstall otherwise it only works until you restart why is it then have to re-install.
                        whit last releeaseof Jdsense
                        usb ethernet work!!
                        i use a generic chinese adaptor usb work!
                        aand a nintendo wii usb adapter work!
                        now im testing ila kernel,,,
                          good! microphone work very well!!!!!
                          wireless work
                          usb ethernet work
                          network location work
                          multiuser is enable, you can create a new user... but after you never can more choose to change
                          the stick is little more hot.....
                          JD do you can modify this kernel? and take driver of it?
                          and use it with your rom... so we have microphone
                          Antutu says 10296 so the OC is unuseful
                          Ila.. what is the forum or internet site where you has take this kernel?
                            To change the user to enable the lock screen.
                            And with its users to change.
                            I can not get it to 4.2.2
                            There is one problem 4.2.2. Dropped frames (jerks).
                            Unfortunately it is not solved by RK3066
                              It is not possible to decompile a kernel. You can't take out drivers. You have to recompile the kernel with the complete sources and you need the configuration. That is a job for a kernel guy, but I understood the kernel lharambr brought here works fine with our ROM. So why changing the kernel?
                              When we get some useful changings together, I will update the ROM, but check what is really necessary. Right now I have not much time.
                              On the list is for an update is so far.
                              flash_image binary
                              multi_user(I don't think that it is possible, it depends on kernel, too.)
                              and the other kernel is option, when he works stable
                              Please explain the improvement you want. We have a debloated rom. I don't want to pack it full now.
                              JDfense
                                4pda.ru http://4pda.ru/forum/index.php?showtopic=437109
