CX803 rk3066 New stock Rom 4.2
No. This system is best.
You can do it yourself
Replacing Finless 2.1 MK808b 4.2
/system/lib/libhardware_legacy.so
/system/lib/modules/wlan.ko,8189es.ko
/system/etc/firmware/WIFI_RAM_CODE
/system/etc/wifi/wpa_supplicant.conf
/ System / bin / Netd
/ System / bin / wpa_supplicant
/ System / bin / wpa_cli
And the kernel
Only as it is not properly broken nand flash.
Originally posted by Iharambr View PostHI
JDfense
You do not know how to permanently disable HW overlay?
debug.composition.type=gpu Does not work.
I googled this line is first mentioned with cm7.2=gingerbread as base. I found no word with higher versions of android than ICS.
JDfense
Originally posted by Iharambr View PostFrom Kent interesting option: http://4pda.ru/forum/index.php?s=&sh...ost&p=26697303
So Kent, you could explain it better in english or german.
JDfense
Hello JDfense.
Do not give much to talk about, you know this better than I do.
I have the ROM from here
http://www.freaktab.com/showthread.p...l=1#post111173 and ported for CX 803.Es seems to work, turn off the sleep mode only works.
Hallo JDfense.
Gibst nicht viel zu erzählen, du weist das besser als ich.
Ich habe den ROM von hier http://www.freaktab.com/showthread.p...11173.genommen und portiert für CX 803.Es scheint zu funktionieren,beim ausschalten funktioniert nur Sleep modus
Originally posted by JDfense View Postlharambr, I don't think that this line in the built will have any effect on android 4.22.
JDfense
I need to include thedisable HW overlay of 4.1 forever, it removes the stuttering in the video which uses HW overlay
can edit classes.dex in Settings.apk?
Originally posted by JDfense View PostPoint me on the kernel and I will put it in the ROM thread as alternative kernel for using microphone, ps3 joypad, ..., ...,
JDfense
thanks to iha
There are currently 2571 users online. 7 members and 2564 guests.
