(ROM) AndroidTV_Project V2 S905X By Team Poison
    AndroidTV Project
    ChangeLog
    -Based Off My PoisonATV Versions
    -Improved stability and performance
    -Brand New Look
    -New Tweaks
    -Amazing Video Quality
    -First Boot might be a bit sluggish due to my new tweaks but after apps update and tweaks are done running you can do a reboot and second boot will be fast and pleasant...
    -Always Use force erase all or erase all option in Usb Burning tool
    -also for people on 4pda i see your using my work at least give credits or maybe developers from there could consider joining us
    Download links
    Originally posted by minixfreak View Post
    AndroidTV Project
    ChangeLog
    -Brand New Look
    -New Tweaks
    Download links
    Coming soon
    hello, when can we evaluate this rom&
      i am having some trouble with my Pioneer plasma tv, i can set the resolution to 1080p @ 24hz but than the x96 1/8 and 2/16 become sluggish ... some movies in KODI play fine but live TV really has lag in this mode. Any advice on how to fix this ? thanks for the work in this good looking rom.
        If you set the refresh rate at 24hz then it will run sluggish, You should set it at 60hz and use the auto refresh (playback settings) at level one. I found this to be the best setting.
        I only change the setting when watching footy, I set the playback setting at level 2. This can cause the box to run sluggish if watching something with low refresh rate as it changes the tv refresh rate to match what im watching.
        When finished i change the setting back to level 1 and change the refresh rate back to 60hz.
          Been using this ROM for a few hours on m8s ii and it is very responsive, quick and smooth.
          I have tried all the previous poison versions and I always seemed to get stuttering video play back. The only previous version that worked was REDPOISON V2.
          This version has perfect video playback however I have run into a problem. When using mx player if I try to use the HW+ codec the video will play but soon as try to fast forward or rewind my box just freezes. I have tried different versions of mx player and also vlc player and still keeps freezing when trying to Fast forward of rewind. Got to unplug box to restart.
          Any idea what the cause could be as never had this problem on any of the previous Roms.
          Cheers for the effort and hard work in producing these roms. My box was a was useless with the original rom.
            I'm happy too. thanks to the author for rom
              looks very beautiful, however wifi does not work with my MX PRO PLUS. and i need the 5ghz for high speed internet
                The problem with my TV is it only can do 1080p at 24hz not 60 nor 50hz, or 720p 60hz. Ill just leave it at 720p because 1080p really laggy.
                  Hi
                  Just tried V2 and it installs and starts fine but soon as I restart my box (mini m8s ii) it will not boot up again it just stays on the boot animations.
                  Tried burning rom again and the same result.
                  Cheers Mate
                    im looking into the issue
                      Nice 1
                      Cheers Mate
                        Why did you leave the development of GoogleTV V1.0 S905X firmware? very good work
                          Yes working on Android tv project ... I think I figured out v2 fix so it doesn't get stuck in bootlogo but I'm at work for will be a bit before I fix and upload
                            The link to Mega says empty folder. Can you give a new link for the ROM?
                              I'll reupload once I fix the boot loop issue
