(ROM) AndroidTV_Project V2 S905X By Team Poison
    Originally posted by smaaz View Post
    minixfreak
    ​​​​​​​Device: H96 pro H3 2/16 905X based
    [18:50:17 996][HUB3-2][Err]--[0x30405004]UBOOT/Partition system/Verify patition/Error result
    I am using usb burning tool v 2.1.6 and at 98% get the following error, please guide.
    Force erase all also u might have to mod to get it working with original firmwar3s bootloader and uboot file
      I am playing safe as for now I can load original firmware for this device, will force erase option let me load original rom later on ?
      How to mod ?? little help will be appreciated
        minixfreak Poison is dead? Or did you just rename it?
        What about Google TV 1.0 ? Are you still working on it?
        Niiice clock patch for X92!! Damn....thanks minixfreak for all the hard work....
          My TV Box: NEXBOX A95X (S905X) 2GB/16GB
          Installed S905X_AndroidTV_V3_Nexbox.img via USB burning tool (Note: SD card method via Burn_Card_Maker does NOT work.).
          Flashed remote.zip via TWRP.
          Everything is working.
            Have the playback setting options been removed from the settings menu ?
            The auto refresh rate seems to be on level 2 and no way to change it.
            Tested S905X_AndroidTV_V3 on mini ms8 ii
            Cheers Mate
              Installed S905X_AndroidTV_V3 on a MiniM8S II V3.1 2GB/8GB via USB Burning Tool V2.1.6
              works perfect for me! :-)
                Do you have playback setting options in the settings menu?
                When i installed this rom the auto refresh rate is set to Level 2 and no way to change it.
                  I have a new firmware coming soon minixfreak firmware ... autofranerate and everything will be back ... but not releasing it till I some testing
                    Nice One
                    Cheers Mate
                      Hi minixfreak
                      Just tried your new release (S905X.img) but unfortunately Google Play Store not working.
                        Originally posted by legnosecco View Post
                        Hi minixfreak
                        It works just go to settings then apps and force close also force erase all ...
                          What is exactly the difference between Poison ATV (versions up to 4.x) and this one Android TV project V2?
                            Just tried to flash minifreak for my x96 mini s905w it gave me enum error and bricked. I try to sd card method to revive box but when I do pin in AV it takes to twrp and not automatically install from sd card. any help?
                              Ignore my last message, i got back to V3. When installing new minifreak rom do I erase bootloader?
                              Edit: Loaded up, wifi does not work (x96 mini 2GB)
                                Thank you !!
                                I did that, USB burning tool with "force erase" and Google Play Store is now working fine.
