(ROM) Minixfreak_OS S905X May25/2019 ""NEW""
    Minixfreak OS Changelog
    Bases:
    -S905W Based off TX3 Mini L firmware
    -S905X Based off TX7 firmware
    -S912 Based off Z6 firmware
    -S912 LPDDR Based TX92 firmware
    Features:
    -AndroidTV OS
    -TWRP installed
    -Optimized Bluetooth and Wifi Drivers
    -Voice Search Added
    -Picture In Picture Added
    -Google Assistant Added
    -External Broadcom Bluetooth Added
    -GamePad Support Added (PS,Xbox etc)
    -Init.d Tweaked to the max
    -Build.prop Tweaks
    -Amazing Themed Icons and wallpapers
    -S912 opengl 3.2 Support Added
    -Amcodec Added
    Fixes:
    -Wifi disconnect fixed
    -Codecs fixed and optimized
    -Various crashes when using certain apps
    -Wifi not detecting mostly Fixed
    IPTV
    Website is https://hustleman.tv/
    When Ordering your service make sure you add recommended By Minixfreak In note section
    3 Service to choose from single and multi connections also
    BEST SERVICES AROUND
    I TESTED ALL 3 SERVICES ALL AMAZING, Pick the right one for you along with your budget
    SAVE 5% OFF YOUR ORDERS, CODE IS " MINIXFREAK "
    Tips&Info
    - Faster boot time
    -Extremely tested tweaks(Some Interfeared with each other) Works amazing now
    -Added Airscreen app (Chromecast alternative)
    -Added ES File Explorer Pro
    -Added STBEMU Pro
    -Added Darkmedia IPTV APP (Works amazing Only English tho) Please sign up for it on https://darkmedia.tv/ Truly Amazing Iptv, Also It updates through playstore automatically when update is available
    -I Put a lot of time into the firmware and hope everyone likes it ?, I cant please everyone with every single device out there? some devices are different and ppl have to face that ? its mostly universal firmware but not completely.
    Thanks Everyone who supported me
    I try not to accept donations with cash itself but people actually sending me the box to develop for , Rockchip and S905X2 will come soon ? Stay Tuned
    Downloads:
    https://mega.nz/#F!5o5B0SII!p-W0crI8UbegQNA80vKSzQ
    working fine on x96 1/8, resolution is lower though, good rom, rest all working fine, using kodi 17.6
      The minixfreak firmware works amazing. Have not tried the new version yet but I will soon. I read the first post, but was wondering if the changelog applies to the original minix firmware or if the changes were made from previous versions. If you don't mind can you specify the changes that were made from minixfreak original? Were the base firmwares changed in this version? Etc.
      keep up the great work!
        I have a a95x nexbox 2gb 8g box and I installed it works but the voice search seems buggy it works one time and when switch it back on from off state it doesn't how to fix this ? Is this due to not selecting force wipe option when uploading rom through usbtool?
          Always force erase all to make sure all previous data is erased
            good day, just joined the forum, i downloaded this rom and applied to my nexbox tv box how do i get the remote to work using the fixes i see in the download folder. i am a newbie first time trying this
              put patches on usb stick then go to terminal emulator and type reboot recovery..... it will boot into recovery ... u need a usb mouse as well or airmouse for it .... then go to install.;... select storage and click usb .... u should see how the patches are
                problem fixed thanks for your help much appreciated
                  Hello good afternoon
                  My most sincere congratulations to Minifreak for her work with this ROM
                  I have a question or doubt: My device is this (https://www.khadas.com/vim1) and I would like to know what is the ROM of all the S905X-based ones that I should download ...
                  Thank you very much again
                    you ould have to use different bootloadfer etc to get it working i believe ... try at your own risk with that device
                      Where i can find and download a different bootloader to get it working on my device ( khadas vim 1 ) Amlogic S905X ??
                      Can you help me PLEASE ??
                      Thank You
                        Is this based on Nougat or Oreo?
                        Never mind, I see that it's Nougat, 7.1.2.
                        Would the OP mind if I tried to port this to the Vim?
                          Port it if u want
                            Please Zahir, make a fork of this ROM for Khadas vim1
                            Please. You Can !!
                            You are great Zahir
                            I now used on my khadas vim1, your ROM ATV Experiencia v3 for Khadas vim1. My friends too.
                            Please Big Zahir, make a ROM for Khadas vim1 of this ROM ( Minixfreak_OS ) for Khadas vim1...
                            Thank you so much
                            I downloaded and flashed the ROM file the image called S905X but it does NOT work in Khadas vim1. Only our logo of the ROM (Minifreak_OS) and the TV screen remains in black, in addition, in the Khadas vim1, the Blue LED stays on and only by pressing the power button perpetually, it continues to start, but if I leave press it, it stays with the blue LED and black TV screen.
                              Originally posted by minixfreak View Post
                              Port it if u want
                              Yeeeaaahhhh Yeeeaaahhhh
                              Thank you minifreak
                              Zahir, lets go !!
                              I'm looking forward to trying it. I offer myself as a tester or "beta-tester". I will speak very well to my friends who also bought the Khadas vim1 for them to try it too. Crossing my fingers and wanting to test your version of the ROM (Minixfreak_OS) for the Khadas vim1 device. I send you a greeting and hug from Spain
