(ROM) Minixfreak_OS S905X May25/2019 ""NEW""
Guest
Originally posted by mAtvXk View PostMinixfreak_OS_REVISED
https://mega.nz/#F!91IU0K5R!VvCOFtu1gagXyG09US3-Ig
what?s difference between the original one from the first post and this one revised?
Originally posted by moscher View Posti installed "Minixfreak_OS_REVISED" on my Box.
It looks fine but i cant get amazon prime running.
when i try to play a video in the prime app
I get a message that i should try in a few minutes again...
Thank you for this amazing firmware Minixfreak_OS_REVISED.I installed it in my Beelink GT1 2GB/16GB model by using SD card method & it went smoothly. But i would want to say that the keyboard that you used is not good. I had lost my remote,so i was using mouse for navigating. Now the leanback keyboard that is being used here won't let me type anything by mouse. So i had to download apk of swift keyboard and sideload it. Then also i could not install it as this rom lacks any sort of file browser.So i had to connect my DS4 controller to it to type. But then somehow DS4 had some weird sensitivity issue which led to irratic response to movement. So it took me around 10 minutes & mountains of patience to get it done correctly. Then only i could login and download other apps required. Havn't tested much, but so far performance seems good.
Also it lacks a basic file explorer. Having it embedded in the firmware wouldn't have consumed too much space i think.
So those are the suggestions from my side- to use some other keyboard like swift keyboard etc & to include a basic file browser.
Tried SD Card method (USB method never worked Win10 didnt connect to device), after short Uploading time, 1 sec maybe, Nexbox a95x 2GB/8GB turned off, only red led led shines.
Bricked
Changed to newest USB burning tool, for Nexbox 195x users very important:
- Import image
- Click on start
- AV button reset + usb cable
Everything else gets to an error
After that go to terminal emulator, use reboot recovery command (AV button + power wont get you to TWRP) then install nexboxremote patch.
Awesome ROM - very fast, thanksLast edited by sekosan; 18 September 2019, 11:12.
Installed the revised S905X_REVISED.img on my MiniM8S 2G/16G, very fast and impressive, but cant get the wifi working at all. Anyone else with a MiniM8S with same probem? Did I download the wrong image? Do I need to apply any patched through TWRP maybe?
Thanks for your help.
BTW I was using the s905x_2G_atvXperience_v2FF image before Wifi working, but would like to test the minixfreak one for comparison.
Checked and looks like my wifi chip is Azurewave AW-NB197SM, hope that makes sense, thanksLast edited by minonano; 22 September 2019, 20:39.
There are currently 63762 users online. 1 members and 63761 guests.
Most users ever online was 63,767 at 18:41 on 20 March 2025.
