(ROM) Minixfreak_OS S905X May25/2019 ""NEW""
Guest
Originally posted by joseac View PostHello, why does the Launcher not be changed? I install a different one and it is changed, but when restarting it returns to the one that brings by default ....
Originally posted by minixfreak View Post
its androidTV Not Regular Android .... find a regular android build .... this is AndroidTV Build
So you can't change the launcher? I'm testing with ATV Launcher https://play.google.com/store/apps/d...vlauncher.free
1. Install a launcher of your choice (I tried HALauncher, ATV Launcher and XBMC Launxher)
2. Start the launcher you installed at least once.
3. Use a file explorer with Root support.
4. Go to system/priv-apps and delete 'leanbacklaunchet' folder.
5. You need to restart you box once or twice and select your new launcher as default.
I personally find HALauncher and ATV more 'mother-in-law friendly' than Leanback.
Originally posted by Zahir View Post1. The inconstant screen resolution is a pain, I agree, and I have fixed that in V2. You should now have 1080p constant through all reboots and power ons. Power menu works better too.
The issue was caused by bypassing Minixfreak's bootloader (in order to avoid problems with USB Burning Tool when flashing another rom). With V2, I have minimized the conflict with the Vim but you will still need to use that three-button routine I mentioned above in order to move to another rom. That works fine for me.
i.e press all three buttons while connecting to USB. Keep all three pressed then release the reset button, holding the other two until USB Burning tool connects. May need to do this once or twice.
2&3. I can't do anything about HDMI-CEC, it's broken in Minixfreak's system.img. And the codes for the Khadas Vim remote are embedded in the official Nougat kernel, which I also cannot use because this rom will only boot up on its own kernel, as I discovered... You will need to use a usb remote/air mouse.
Sorry about that! Still, a very quick and capable rom, enjoy it for what it is..
hey bro, hope you are well, is possible for you to upload this file again ?
thanks again
There are currently 63751 users online. 1 members and 63750 guests.
Most users ever online was 63,751 at 18:39 on 20 March 2025.
