MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16
    Specification
    Brand: MECOOL
    Model: KM9 Pro
    Type: TV Box
    GPU: Mali-G31
    System: Android 9.0
    CPU: Amlogic S905X2
    Core: Quad Core
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 16G ROM
    Max. Extended Capacity: TF card up to 64GB (not included)
    Decoder Format: H.263, H.264, H.265, HD MPEG4
    Audio format: AAC, FLAC, MP3, OGG, RM, WMA
    Video format: AVI, DAT, ISO, MKV, MP4, MPEG, RM, WMV
    Photo Format: BMP, GIF, JPEG, JPG, PNG, TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI 2.0,LAN,TF card,USB2.0,USB3.0
    Language: Multilanguage
    HDMI Version: 2.0
    Other Functions: Others
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Product weight: 0.1100 kg
    Package weight: 0.4000 kg
    Product size (L x W x H): 10.00 x 9.80 x 1.95 cm / 3.94 x 3.86 x 0.77 inches
    Package size (L x W x H): 19.50 x 13.00 x 6.50 cm / 7.68 x 5.12 x 2.56 inches
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x Voice Remote Control, 1 x HDMI Cable, 1 x English User Manual
    Gearbest
    Terriible WIFI not sure its just my box or its common , reminds me of the KM8
      Hello Uscool
      I received mine for a review.
      i face also an issue with the WIFI.
      This sis slow and go to timeout on many action, even to register my account was not working.
      I had to connect it thru the ethernet to have it working.
      Have you same symptoms ? Any fix you found ?
      Did you try the NETFLIIX patched version ?
        Originally posted by planetenumerique View Post
        Hello Uscool
        Hi, so its common issue reminds me of the Mecool KM8 same issue was never fixed, I dont know if its Hardware issue or can be fixed with software update i get very low speed and also cuts out, very disappointed because other then that the boxes runs very well even Chromecast works , Price is very good for box with s905x2 and ATV 9
        Also reading the reviews on it on Gearbest no one complains about the WIFI ?
          Thanks to our Friends at GEARBEST, today we can get up close and personal to the
          Lest have a look see at what it has to offer
          Specification
          Brand: MECOOL
          Model: KM9 Pro Classic
          Type: TV Box
          GPU: Mali-G31
          System: Android 9.0
          CPU: Amlogic S905X2
          Core: Quad Core
          RAM: 2G RAM
          RAM Type: DDR3
          ROM: 16G ROM
          5G WiFi: No
          Bluetooth: Bluetooth 4.0
          Power Supply: Charge Adaptor
          Interface: AV,DC 5V,HDMI 2.0,LAN, TF card USB2.0 and USB3.0
          Language: Multi language
          HDMI Version: 2.0
          Package Contents: 1 x TV Box, 1 x Power Adaptor, 1 x Voice Remote Control, 1 x HDMI Cable, 1 x English User Manual
          Should be enough in the tank to make this a worthwhile unit and a neat little streaming Unit:
          The Box
          What's in The BOX
          Remove the lid
          Remove the PCB
          Top View
          Ports
          Remote
          Gearbest > MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16 <
          Don't forget 39.99 with GBCNKM9C01 coupon at Gearbest
            Startup all good and very easy used the Phone with find my device.
            Minute or so all done up and running.
            Installed and updated apps, Aptoide for the no ATV type.
            Running Android 9 ATV much the same as all the others.
            KM9 Classic appears zippy enough with the 2/16gb and should do most.
            Remember 2/16 was the norm not so long ago.
            Netflix not happening (unless you find the one that was kicking around awhile ago)
            Remote easy to work a good feel in the hand, and Voice also working well as expected
            You tube looks good and with most others
            Amazon Prime Video doing the job well.
            For the Price this could be a good Mi Box replacement plus a few extra's
            ...Soon
              More test as the come to hand on the MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16
              So far So good I feel
              UI
              DRM
              YT
              WiFi ok here
              AIDA64
              Casting Working Well
                Benchmarks? Those coming next?
                For the price with coupon, it is the best budget tv box to get right now.
                • trebor
                  trebor commented
                  Editing a comment
                  Yep soon much the same as other 905x
                Are you sure about the WIFI ? because its very bad for me max is like 15mb I have 220mb down line, i tried every channel in router settings and router is in same room,
                I have tested same internet and location with X96 Max gets around 66mb, Mecool M8S 44MB, X96 mini 33mb, Xiaomi Tv Box with 2.4ghz gets 44mb ,
                Both KM9 Pro Classic and KM8 have same Wifi Issue also another user posted same issue here
                • trebor
                  trebor commented
                  Editing a comment
                  What you see is what I get
                  Sometimes 50 sometime more
                  All I can suggest Try other channels on the router,
                  Check what channels have least amount of use with WiFi analyser or similar
                  Could be interference from BT or other things
                  Also if you keen the internal antenna is close to the weight block/heat sink...Moving it away from all that meta may help...
                A few more test, pretty much the same as most other 905x2 nothing worse well maybe the WiFi needs a tweek
                Most of the Online streams all good (major)
                Pretty Zippy
                SD Card test: Looking OK
                Geekbench
                CPU-Z
                Analiti Further tests :
                WiFi is a bit ordinary but works well enough.
                Thanks to Gearbest > MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16 <
                  Hi, i did go through each channel 1 to 13 and same with all, and opened it didnt look like anything in the way maybe my box was just fault with wifi ? i dont wanna risk buying another if its not
                    Hi all , Is Chromecast working?
                      Couldn't resist. Might be a candidate for internal/external antenna mod but so be it. For $40 bucks, worth it to me. Certified, Android 9, S905X2, whats not to like? Thanks trebor .
                      A bit value engineered but not bad. Still a smoking deal. Cant wait to check it out!
                      • trebor
                        trebor commented
                        Editing a comment
                        Yep good to see, yes thinking the same with the antenna, but works well I find as is here.
                        Previously 2/16 was the deal then game in 3gb now the 4gb, does well for what it has
                        Hello, one question, is Crhomecast working as advertise??Did you test it?
