MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16
Originally posted by delacosta78 View Post
They are now giving me three options by the warranty: To refund the money to Gearbest wallet, to refund the money to my credit card or ship another device for free, I'll definitely take the second option XD.
Originally posted by delacosta78 View PostHere's the firmware they sent me, it may be useful to any of you, I'll never buy Mecool devices again if they continue with that WiFi issue:
https://mega.nz/#F!9N5UGQBB!iQrU3BwjVneL93A8ffShoQ
This device has an Ampak WiFi module, the only Ampak modules that perform great are the ones with MIMO 2T2R, which are the AP6356/S/SD and AP6359SA.
Originally posted by RiCkLaR_atvX View Post
The Wifi issue is all due to a low quality budget WiFi chip that is in this device, compared to the Mecool KM3 which has an Ampak MIMO 2T2R wifi module and it gets great WiFi performance. So to be safe in future buys always make sure the device has WiFi band AC because then you know chip is more a modern chip release and not old release with N band and lower. Another buying tip is look for MIMO or 2T2R in the device specs which is 2 Transmitters and 2 Receivers antenna. Or just wait for Trebor or someone else on FreakTab to do a full Tear-down review where you can see the Wifi Chip and then reference it on Google search to find its specs so you can make intelligent decision about buying that device.
MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box (https://www.gearbest.com/448243601-_gear?lkid=38595802) https://des.gbtcdn.com/uploads/pdm-desc-pic/Electronic/image/2019/05/27/1558949834672812.jpg MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box (https://www.gearbest.com/448243601
Originally posted by uscool View Post
Trebor posted this earlier in this thread
https://i.imgur.com/qY43qfP.png
Hi all, I'm expering issue with passthru audio via HDMI
Before was not working at all, now is working but during the film from time to time it stop for 2 3 second then work again.
That's for both kodi and Plex
Any suggestion?
Any chance to have a new firmware ( my box already came with the one posted here).
I run an experiment by connecting the KM9 through an ethernet cable to a TP-Link extender, turns out the internet speed was equally slow as using the internal WiFi.
When I connect the device directly to my router using the same ethernet cable the internet speed is fast and stable but I don't understand why using the extender I didn't get at lest an acceptable speed, the extender had an strong WiFi signal from my main router so that couldn't be the reason.
However, I run a speed test using Analiti app and I got the full down/up internet speed exactly as when the device is connected directly to the router but using apps like YouTube I get poor speed measures like the attached screenshot, which says the quality is 1920x1080 but it goes very quickly to a low resolution.
Looks like this problem is not related to the WiFi chip inside this device but perhaps the Android TV firmware not optimized to handle a WiFi signal?
Why the speed wasn't fast enough if I was using an ethernet connection from an extender with a strong signal strength?
Originally posted by delacosta78 View PostI run an experiment by connecting the KM9 through an ethernet cable to a TP-Link extender, turns out the internet speed was equally slow as using the internal WiFi.
The 'Connection Speed' displayed in YouTube is reference to your bitrate
I'm going to test other apps to see what happens because I'm starting to believe the YouTube app is failing to work with the WiFi, I'll reply with the results.
I was doing the speed test with Analiti the wrong way, it was set as default to "Multi-Server HTTP" method but I switched it to NDT (Single TCP connection) and the real speed test result shows a very slow download speed of 2 Mbps out of 8 Mbps by using the TP-Link extender!?.
I really want to understand why the speed test is so slow by using the extender connected to the main router wirelessly and the KM9 connected to the extender by an ethernet cable, it shouldn't be that slow considering the KM9 is operating as it was connected directly to the main router by the ethernet cable since it's not using its internal WiFi chip.Last edited by delacosta78; 09-30-2019, 02:35.
I borrowed a D-Link router from a friend and set it up as a wireless repeater, I connected the KM9 to any of the ethernet ports and made more tests:
1) Using YouTube, at first it gave my maximum download internet speed (8Mbps):
2) But then it went down and it's stuck in this quality, it doesn't go faster than 3Mbps:
3) Using analiti, the average download and upload speed was similar to the second test using the TP-Link extender:
It's pretty obvious the problem is not the WiFi chip inside this device as other people claim but the Pie firmware not optimized to work with WiFi connections of any kind.
Originally posted by alessiopcasa View PostHi all, I'm expering issue with passthru audio via HDMI
Any suggestion?
This device doesn't have Dolby Digital or Dolby Digital Plus downmixing to stereo (Aka Dolby Audio), it only supports Passthrough, that's the reason why (at least in my case) I don't have audio at all with Plex and other apps using those codecs, DTS is the same story, I haven't test Kodi but I assume it's the same problem.
My issue is with the Passthrough that is not stable and from time to time stop sending audio for a couple of seconds
There are currently 4172 users online. 9 members and 4163 guests.
