Does any one have any suggestions for customizing the Home Launcher?
MECOOL KM9 Pro Classic Google Certificated Voice Control Android TV Box 2/16
What are peoples thoughts on the home launcher on these boxes, I know its the TV OS on these boxes but I would have thought the home launcher would have been more customization than it is and I do get why they have included the side launcher app. The Box I have is the KM9 Pro Deluxe and at the moment I think I prefer my other android box which is also running android 9 but not the certified version.
Originally posted by Richardj View PostWhat are peoples thoughts on the home launcher on these boxes, I know its the TV OS on these boxes but I would have thought the home launcher would have been more customization than it is and I do get why they have included the side launcher app. The Box I have is the KM9 Pro Deluxe and at the moment I think I prefer my other android box which is also running android 9 but not the certified version.
Enviado de meu ASUS_X00TDB usando o Tapatalk
I've been using ATV launcher for some time now, lots of customization although there is no way to set any launcher as default on the Android TV OS so when you power the box off and then resart it'll automatically use the built in launcher, what I have been doing is to put the box to sleep this way the ATV launcher is running.
Guys has anyone came across audio issues with this box? Using the new Disney+ app all is well, but when I exit Disney+ and open any other app, say YouTube or Netflix, I get no audio!! I'd say this was an issue with the app, but it also happens in the ATV HBO app so obviously these apps are hijacking audio somehow and even force stopping them does nothing.
I've tried changing ATV system sound settings, but the only way I can get audio back in all apps is by rebooting the box.
Originally posted by KingEB View PostGuys has anyone came across audio issues with this box? Using the new Disney+ app all is well, but when I exit Disney+ and open any other app, say YouTube or Netflix, I get no audio!! I'd say this was an issue with the app, but it also happens in the ATV HBO app so obviously these apps are hijacking audio somehow and even force stopping them does nothing.
Envoyé de mon SM-N950F en utilisant Tapatalk
Check AndroidPCtv.com the blogger there posted a Disney+ fix and also check YouTube some videos have been posted on the subject as well.
Originally posted by Teki View Posthello where did you download Disney + .apk? I tried several but each time 'I have the video but not the sound.
It looks like you have to set 'digital audio format' to auto in the box audio settings and enable surround sound for audio to work in Disney+. However, and it may just be me, but if you do this and are just using your TV speakers you may end up with the issue I'm having. If you're using a soundbar or av receiver you might have no problems!
Hi Guys.
Could you please help me with 2 questions:
1) Have any of you had problems with the ethernet connection?
It is frequently connected, but the internet does not always work and I get unplug and plug the cable to get it works.
2) When I select the HDMI port of the TV the TV BOX turns off and I must turn it on again, then if it works correctly. I have the CEC option turned off.
Thank you very much
Hi, I share you about how to get Netflix Android TV Version for MECOOL KM9 PRO CLASSIC.
1)Install ROM B2oba17 from MECOOL KM3 THREAD.
LINK ROM: https://mega.nz/#!d4oA1AJb!cpdJ6HB8zI...
VIDEO TUTORIAL:https://www.youtube.com/watch?v=cjrJIH8nSas
2)DOWNLOAD AND INSTALL TWO NETFLIX FROM YABILO VERSION
1. https://drive.google.com/file/d/1qKD...DLs91A4uy/view
2. https://drive.google.com/file/d/1qkK...8F4X-Ywcg/view
3) DOWNLOAD and INSTALL BURNKEYTOOL 1.06apk
BurnKeyTools APK18414 DownloadsA tool to fix the NETFLIX ERROR NW-6-404 error. Regenerate the TV Box certificate system and make it again valid to playback Netflix in HD quality. For now it is only compatible with some affected TV-Box. Supported devices are: M8S Pro L, M8S Pro W, M8S Pro +, M8S Pro (S912), K Series, A95x Pro. Download Now!Size: 400KBVersion: […]
4) REBOOT YOU KM9 PRO CLASSIC
5) You open netflix yablio patch (black logo) you closed and open netflix with blank logo and logon
6) ENJOY IT
NOTE : FIX MIC of Voice Control ,- You need to add bluetooth and synchronize remote if don't work you're enter in setting application ,all and system application you're force stop android tv core service
Androidtv 10 released on mecool website https://mega.nz/folder/LNtB3Zqb#jHONGu48Pd52PRmsxlssvg
Works great on pro classic.
Originally posted by canadien View PostAndroidtv 10 released on mecool website https://mega.nz/folder/LNtB3Zqb#jHONGu48Pd52PRmsxlssvg
There are currently 1768 users online. 1 members and 1767 guests.
