[ROM] Beelink GTKing VolksWare by Sasvlad with TWRP English and Russian Version
Sasvlad , has you can check in russian foruns
(https://4pda.ru/forum/index.php?showtopic=948258) there are many people reporting that is an ethernet problem with this boxs. Good for the ones that don?t have problems, but for the one having a faulty box are in the Hands of the Devs that make Custom Firmwares to try to fix thing up, because we can?t hope for Beelink support.
Originally posted by boot2k3 View Post
It possible that it's an hardware issue, not software. 5 of 10 tested old revision boxes were with such issue.
So.. is not only my personal problem, but from many buyers. Beelink should make a Recall and send new box?s to evey one that have bad hardware .
Hi, I would like to install SuperSU on the latest Rom for GT-KING I tried with 2.79 and rebooted and it bricked the GT-KING but recovered by re flashing latest rom, can anyone suggest the best method to install supersu 2.82 preferably without having to install this custom Volksware ROM and not compromising the Beelink rom. Thanks
Originally posted by chrmica View PostHi, anyone suggest the best method to install supersu 2.82 preferably without having to install this custom Volksware ROM and not compromising the Beelink rom. Thanks
on a side note, this entire thread is for the custom ROM VOLKSWARE
NOT four side discussions on Hardware software and miscellaneous King problems. Please help us keep on topic. General discussions for the king can be found elsewhere, and if not you're welcome to start one respectfully thanks. Honor the developerLast edited by ClarkKent; 02 September 2019, 20:12.Kris....don't forget my boxes! Okay?
Originally posted by chrmica View PostSorry for the inconvenience caused.Kris....don't forget my boxes! Okay?
Originally posted by theholyguy View PostI would like to try, but since there's no English version of the 1.2 for the B922x I must wait.
Originally posted by Sasvlad View PostYou can try to start with the Russian version. In Russian, only Launcher and droid TV settings. Launcher you can replace with any other. I would be interested in your opinion. If you like it, I will tell you how to replace files with English ...
Enviado do meu SM-G9650 atrav?s do Tapatalk
i will try de official 904 and then we will see.
thanks great job
Just installed your v1.2 for B922. Selected english language on install. Changing to ADW or the english lighthome launcher you posted removes any russian from what I can see. I have tried all the other custom roms and stock inc v904p0 - yours seem very smooth. Some of my IPTV pro m3u streams that were are bit stop start on other roms are for whatever reason now running smoothly. I will stick with your rom for the present and give it a good workout. Many thanks for your hard workLast edited by sesdave; 18 September 2019, 09:13.
There are currently 4151 users online. 0 members and 4151 guests.
