[ROM] Beelink GTKing VolksWare by Sasvlad with TWRP English and Russian Version
- I've been using the sd card method from the start, all the roms from 1.0 to 1.3 work fine. I'm having trouble burning 2.0 to the sd card. I'm using burn card maker v2.0.2. The program keeps stopping when I hit make. I tried the newer burn card maker and I cant seem to figure it out. I dont have a usb to flash the box with. I have the s922x
I get the "Parse burning image fail" as soon as I select the firmware, box not attached to computer yet. All of the other ROMs load without issue, only this firmware does this.
Originally posted by couch potato View PostWhat program will work for sd card method?
Originally posted by couch potato View Post- I've been using the sd card method from the start, all the roms from 1.0 to 1.3 work fine. I'm having trouble burning 2.0 to the sd card. I'm using burn card maker v2.0.2. The program keeps stopping when I hit make. I tried the newer burn card maker and I cant seem to figure it out. I dont have a usb to flash the box with. I have the s922x
Dear Sasvlad!
Thank you for Your nice work, great! I use Your rom but i have an issue whuch is not only with your rom. I have a Samsung soundbar Hw-q90R and a Samsung TV QE55Q6FNA 4k UHD.
When i connect the GT-king dirrect to TV HDMI is O.K. When i connect the box to Soundbar HDMI in and the HDMI(ARC) to TV (for the Dolby Atmos) the video signal is lost, have to connect disconnect randomly cables for getting back the signal. First i thought its a Soundbar issue. But if i try anodher 4K device example xbox one s the HDMI issues non exist. After that i accepted this is a incompatibily between soundbar and king. But i install Coreelec to the king and voila hdmi issue isn't exist. So it have to be firmware issue mainly in the stock firmware too. Sorry if it was to long, but it made me crazy from 2-3 days. Could ou imagine what the trouble is? Thank You again for the firmware
Originally posted by Sasvlad View Post
This is a common Android 9.0 problem on this processor. Only Ugoos in Android was able to make passthru HD sound. In coreelec it works without problems.
There are currently 2718 users online. 0 members and 2718 guests.
