As far as I know, passthru HD sound in GTKing does not work.
[ROM] Beelink GTKing VolksWare by Sasvlad with TWRP English and Russian Version
Originally posted by Sasvlad View Post
May i ask you other issue?
I would like to try your rom, at this moment i use the custom rom of a dev-colleague.
To make the updates on that rom i used a TWRP backup of data only to recuperate my apps and all configurations and it worked well.
Can i use also the data-backup after installing your actual rom and then with TWRP recover the data backup. Or is this data backup connected with the other rom and will not work with your rom?
Originally posted by tombraga View PostI would like to try your rom, at this moment i use the custom rom of a dev-colleague.
It is possible, but still I prefer a clean installation.
There will be no conflicts then? Principally with the launcher? I use SquareHome Launcher actually. But which Launcher is defined as standard launcher on the box is not defined in that TWRP-data backu, right?
I get the "Parse burning image fail" as soon as I select the firmware, box not attached to computer yet. All of the other ROMs load without issue, only this firmware does this.
I can load the img with the newest Burning tool, but i have the other box B922, sorry, so i cannot help, good luck.
I see, now i understand,
I can load the img with the newest Burning tool, but i have the other box B922, sorry, so i cannot help, good luck.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
But you load other img.file than me, you have the 922x box, right? so maybe some wrong with your img.file,
You made the md5 hash check after download?
My box S/N 95X2..
Never tested the md5, since I do not know how to do it. (I see where Sasvlad pointed you into the right direction).
Edit: Ran the md5 check, but numbers did NOT match. But that should not have any impact on the file loading into the burning tool.
certutil -hashfile GTKingC:\Users\clark>cd Downloads
C:\Users\clark\Downloads> certutil -hashfile GTKing_VolksWare_by_Sasvlad_v.2.0_906P0_922Х_Engli sh.img
SHA1 hash of GTKing_VolksWare_by_Sasvlad_v.2.0_906P0_922Х_Engli sh.img:
542540bb18c35c9988e4ad3a57355f69e8d90394
CertUtil: -hashfile command completed successfully._VolksWare_by_Sasvlad_v.2.0_906P0_922 Х_English.imgMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Sasvlad i installed now the v2 rom, was running well.
but after first boot there were no chrome, es explorer and smart youtube icon on start screen.
how can i change this?
also i dont have the navigation bar below on the screen
how can i activate this nav bar? (and also the notifications above?
thanks for your great job
NavBar I got now - resolved
Very good first impression, thanks
There are currently 2227 users online. 2 members and 2225 guests.
