Patched libmedia.so for CS968 stock firmware to enable XBMC's spdif/hdmi passthrough.
The original firmware already support passthrough, but the xbmc can't use it properly. However, the passthrough can be enabled by a hack. This hack include two part, one is a modified libmedia.so. the other is a tweaked XBMC, for detail referred to the awesome dude stafstrom who found this solution (also the download link of tweaked XBMC can be found there): http://minixforums.com/threads/how-t...nd-spdif.2071/.
As he mentioned it is a binary patch, so I figured it might be possible to do it myself on my CS968. I spent some time figuring out what has been patched. And the result is this working libmedia.so which you may find in the attachment.
How to use:
1. mount /system as rw
2. replace /system/lib/libmedia.so with this new file
3. reboot
4. enjoy!
Sorry, I don't use xbmc, but I will try it. I'm so far more a tablet guy.
I think we should try to built a rom with 1080p base. Collecting the issues is the first step. I reflash the cloudnet 1080 / 2MP and check deeper.
Issue list start:
XBMC
Flash player
and what else?
All together we will get a smooth and stable rom.
My TV is LG 42" - 1920x1080.
Original Firmware (factory) - 1920x1080 = ok.
CS968 Custom Firmware -- "GEASS" -- ver. 1 - 1920x1080 = ok.
Firmware - CR11S_200M_cloudnetgo_ap6210_20131105_update = NOT ok.
Firmware - htc_t018_pubilic_ap6210_20131122 = NOT ok.
XBMC, which is very good media center, and a must be app in your tv stick in my opinion, recently, we get some questions about how to run xbmc better with the newest rk3188 quad core mini pc. and after search some information, we find this solution: 1 The offical 12.0 XBMC version don’t work […]
Tech1, we are talking not directly about libmedia. This will be a later step. I'm searching for the best firmware to built a rom with some improvements.
Wepipsum I will upload the ROM I mean later. Then you can check, if it works really in 1080.
