Patched libmedia.so for CS968 stock firmware to enable XBMC's spdif/hdmi passthrough.
Originally posted by Tech1 View PostDid you test this ROM out yet ...? Is It truly 1080p ...? I will test this ROM out and pre-root it ... Plus I will add the libmedia.so hack to it ...
During the boot the screen is flickering.
I returned firmware: CR11S_cloudnetgo_ap6210_1080p_20131019_update.
Originally posted by webipsum View PostHere it did not work. After entering the Android OS, the screen goes black.
I returned firmware: CR11S_cloudnetgo_ap6210_1080p_20131019_update.Last edited by Tech1; 20 December 2013, 06:07.
This update version of cloudnetgo works so far good. Xbmc runs not bad, but some add ins fail.
The main improvement seems to be that it works good in both hd resolutions.
@tech1
How do you know that there are different manufacturer? It could be one manufacturer, who deliver on orders for branding. Mine has no serial no., it is possible the original without any branding.
But there are possible different revisions with changes in the hardware parts.
JDfense
Optical passthrough only works for dts not ac3
Originally posted by Tech1 View PostPlease Note:The patch fix is built into this ROM ....
Originally posted by hillyu View PostThe original firmware already support passthrough, but the xbmc can't use it properly. However, the passthrough can be enabled by a hack. This hack include two part, one is a modified libmedia.so. the other is a tweaked XBMC, for detail referred to the awesome dude stafstrom who found this solution (also the download link of tweaked XBMC can be found there): http://minixforums.com/threads/how-t...nd-spdif.2071/.
As he mentioned it is a binary patch, so I figured it might be possible to do it myself on my CS968. I spent some time figuring out what has been patched. And the result is this working libmedia.so which you may find in the attachment.
How to use:
1. mount /system as rw
2. replace /system/lib/libmedia.so with this new file
3. reboot
4. enjoy!
Att: libmedia.so for cs968 stock firmware.
for 15-10-2013 version:
Happy tweaking and hacking!
SPDIF setting in Sound Device Manager getting lost after power cycle.
HI hillyu,
I'm using SPDIF output to connect CS968(clone) box(android 4.2.2) to my audio receiver. So I select ROCKCHIP-SPDIF in the Sound Devices Manager and then there is output through SPDIF(optical). However if the device is powered OFF any time, the sound device setting reverts back to the default setting(analog audio out) and there is no output through SPDIF. Again I have to set SPDIF in the Sound Device Manager and it lasts only till next power OFF. Will this patched libmedia.so solve this issue also? If not, do you have any other suggestion to fix this?
How to use:
3. reboot
4. enjoy!
Help!! Mine gets hung at reboot!!!
Luckily it responds when I press the reset button with a wooden pick.It seems the device restores all the /system directory when I press reset, because the tweaked libmedia.so disappears and the backup I did of this file also disappears ( I renamed the original libmedia.so to libmedia.so.old) but I still have the same problem, no 5.1 sound at all.
Do you have any other tweaked libmedia.so that could help me?? I really don't want to change the firmware 'cause I am so newbie in these things and a little coward...
There are currently 1781 users online. 3 members and 1778 guests.
