This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GTMini-A ROM.
Please read the entire post before asking questions. Thank you.
This ROM is for the GTMini-A TV Boxes I've converted it from Android TV to Standard Android.
I have figured out a way to keep DRM Widevine L1 (Netflix Certification) and convert it to Standard Android.
In order for Netflix to work in HD you must use the Android TV version of Netflix App, this is pre-installed in this ROM.
(There has been some hardware variants so please read carefully.)
Best thing to do before flashing your box is to check which Serial Number you currently have on the bottom of your box.
I've made 2 different ROM's for these boxes one with starting SN: 95X2 and another one for SN:B95X
(confirmed to also work with SN:B905 use SN:B95X ROM ) Please download the correct ROM for your box down below.
This ROM is for the Beelink GTMini-A S905X2
Changes/Mods & Tweaks Alvatech ROM:
- This ROM is based off of Beelink's Firmware.
- Widevine L1 (Netflix Certification) DRM is still intact.
- Removed unneeded apps that Beelink had installed.
- TWRP Recovery 3.2.3-1 by TeamWin
- Cleaned up Beelink's scripts that I don't use in this ROM.
- Nicer mouse cursor for easy viewing.
- Two Launchers: Square Home 3 , Android One Launcher.
- Pressing the F9 Button on keyboard brings up new android TV Settings from the right side of the screen.
- Added TV Settings in app drawer for users who don't have the F9 key on their keyboard.
- Additional Apps: X-plore File Manager, Smart YouTube TV, Kodi, & Power Menu (With Recovery Boot Option)
- Netflix ATV version (needed for HD)
- Added additional support for more Remotes such as Minix A2 Airmouse and more.
- Added support for controllers and joysticks. (Xbox,PS3 & PS4)
- Removed purple highlight from Settings.
- libamcodec added & registered.
- Removed and cleaned up files / libraries that are no longer needed.
- Added Multi Webview options under Developer options / WebView Implementation .
- Fixed bug with keyboard "Enter" Key.
- Updated Gapps
- Added Google Clock.
- Added Android TV Remote Control.
- Alvatech Boot Logo & Boot Animation
- New Wallpaper
- Other changes, I'll add them as I remember.
- Made 2 different ROM's for the different serial numbers.
- All changes from above still apply.
- Added Extra options in TV Settings, such as Screen Saver Options
- Added Backdrop from Android TV for screen saver. You can change when to initiate it in TV Settings.
- Google Clock (can be used as a screen saver too).
- Double click home button brings up Recent Apps in Grid View.
- Long Press on home button brings up Google Assistant.
- Long Press microphone button on remote and keep holding down while talking into mic for Google Assistant.
- Updated Apps: Kodi 18.5, X-Plore File Manger, & Smart YouTube TV
- Fixed Notifications from Netflix.
- Updated Gapps & Permissions.
- Other small changes.
A token of appreciation is always welcomed. Thank you!
Donation Link Here
Notes:
Please read the "Extra Tips Section" on the 2nd post for additional help.
When box boots for the first time only, installation is still going on in the background please be patient for it to load completely.
When you connect the box to the internet for the first time google dependencies will need to be updated, please allow for these updates to finish.
Download ROM for SN: 95X2:
GTMini-A_AT_V3.0A_DRML1
Download ROM for SN: B95X:
GTMini-A_AT_V3.0A_DRML1_B95X
Installation Instructions:
Recommend Using Amlogic's USB Burning Tool. SD Card Method can be used.
Very Important! when you flash your box either by USB or SD-Card NEVER use the option Force Erase All only use the Normal Erase option or you will lose DRM Widevine L1 (Netflix Certification).
Click needed link down below to download.
USB Burning Tool Method: Amlogic's USB Burning Tool
SD Card Method: Amlogic's Burn Card Maker
1ST BOOT TAKES ABOUT 5-6 MINUTES, SO PLEASE BE PATIENT.
THIS DELETES ALL YOUR DATA SO DO A BACKUP IF NEEDED! USE THIS AT YOUR OWN RISK!
THESE BOXES ARE VERY PICKY IF YOU FLASH IMPROPER OR FLASH WRONG BOOTLOADER YOU CAN LOSE DRM WIDEVINE L1 OR EVEN DAMAGE YOUR BOX.
This is to share my work with everyone and to try to make these TV boxes more enjoyable.
I will try my best to answer or help with any questions and or concerns as soon as I can.
If something doesn't function properly please let me know with as much detail as possible and I will try to fix it.
I HOPE YOU ENJOY IT AS MUCH AS I DO!!
Thank you Beelink for the sample hardware.
To help support FreakTab you can purchase one of the following:
Purchase the GT MINI at Gearbest & click
Purchase the GT Mini-A at Gearbest & Click
Purchase GT Mini A 2 at Gearbest & Click
