[ROM] Beelink GTMini-A ALVATECH Android (8.1 Oreo) S905X2 Widevine L1 DRM (Netflix Certified)
Originally posted by mielcar View PostHi Alvatech is there any chance this rom will work on H96max X2 S905 box?
I don't know I don't have that box. But like I've mentioned before I had all my threads / posts deleted at one point and it's hard for me to remember and I can't reference back to them anymore. But I think I remember someone has tried this ROM on the H96Max X2 but maybe their ethernet didn't work. But I can't really re-call at the moment, sorry. You would have to try to find out at your own risk.
Thank you,
Alvatech
Originally posted by adame1996 View PostHy Alvatech!
What do you think? Is it compatible with beelink gt1 mini?
Yes it's compatible with GT1-Mini but it doesn't mean you get to play Netflix in HD because the regular GT1-Mini doesn't have the Netflix keys originally in the box. So it will work but you would need to install your own version of Netflix app and it will only play in SD.
Thank you,
Alvatech
What you're referring to there in the picture is the search bar. In that picture you see I used Square Home Launcher 3 and in there yes you can remove it or add it. But if you're using the other launcher I have included, that one you can't remove it because it's part of the launcher.
Thank you,
Alvatech
Originally posted by atvbca View PostExcellent ROM, thanks for sharing ALVATECH! If I wanted to convert this back over to Android TV which files would I inject from the stock ROM? Just the launcher and the framework folder?
It will be a lot more than just that. The best thing to do if you decided to go back to Android TV is to flash back the factory ROM from Beelink.
Thank you,
Alvatech
I have thought of making an updated ROM for this box. But at the moment busy with some other projects. I will see what I could do, but no promises and sorry I can't give a time frame since it's an idea at the moment. But when I get some time I will see if I can do that.
Thank you,
Alvatech
Hello everyone,
I've now made an Android TV 9.0 PIE (ATV) version for this box. If you're interested please see links down below. Since Beelink has not made an Android 9 ROM for GT-Mini-A, your box won't be able to play Netflix in HD though.
Thank you,
Alvatech
Alvatech ROM ATV 9.0:
[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2 Please read the entire first post before asking questions. Thank you. This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT1-Mini ROM. This ROM was converted into Android TV if you're looking for a Standard
Hello everyone,
I have updated this ROM a bit. Nothing crazy but I have added some features and other updates that I felt were needed. Please read entire first post and change log before asking questions.
Also yes, you would need to re-program your box completely you can't update it through TWRP. If you like you can make a Data backup with TWRP and backup any other files such as pictures or Kodi Backups and then restore Data partition with TWRP, this should work for the most part. Please search the web on how to if needed.
Thank you,
Alvatech
Hello,
As some of you users know. It seems the Netflix keys have been dropped again on these boxes. But it looks like they released another fix. You would need to get a hold of Beelink directly to new keys to re-flash / re-key your boxes. I put a link down below for those who need it.
Thanks,
Alvatech
Link for new key request from Beelink directly:
Originally posted by ALVATECH View Post
Yes, please read 2nd post. If you install Magisk and follow those instructions this will hide root and bypass safety net on your box.
Thank you,
Alvatech
There are currently 1710 users online. 0 members and 1710 guests.
