[ROM] Beelink GTMini-A ALVATECH Android (8.1 Oreo) S905X2 Widevine L1 DRM (Netflix Certified)
Originally posted by ALVATECH View Post[ROM] Beelink GTMini-A ALVATECH Android (8.1 Oreo) S905X2 Widevine L1 DRM (Netflix Certified)
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GTMini-A ROM.
Please read the entire post before asking questions. Thank you.
This ROM is for the GTMini-A TV Boxes I've converted it from Android TV to Standard Android.
I have figured out a way to keep DRM Widevine L1 (Netflix Certification) and convert it to Standard Android.
In order for Netflix to work in HD you must use the Android TV version of Netflix App, this is pre-installed in this ROM.
(There has been some hardware variants so please read carefully.)
Best thing to do before flashing your box is to check which Serial Number you currently have on the bottom of your box.
I've made 2 different ROM's for these boxes one with starting SN: 95X2 and another one for SN:B95X
(confirmed to also work with SN:B905 use SN:B95X ROM ) Please download the correct ROM for your box down below.
This ROM is for the Beelink GTMini-A S905X2
Changes/Mods & Tweaks Alvatech ROM:- This ROM is based off of Beelink's Firmware.
- Widevine L1 (Netflix Certification) DRM is still intact.
- Removed unneeded apps that Beelink had installed.
- TWRP Recovery 3.2.3-1 by TeamWin
- Cleaned up Beelink's scripts that I don't use in this ROM.
- Nicer mouse cursor for easy viewing.
- Two Launchers: Square Home 3 , Android One Launcher.
- Pressing the F9 Button on keyboard brings up new android settings from the right side of the screen.
- Added TV Settings in app drawer for users who don't have the F9 key on their keyboard.
- Additional Apps: X-plore File Manager, Smart YouTube TV, Kodi, & Power Menu (With Recovery Boot Option)
- Netflix ATV version (needed for HD)
- Added additional support for more Remotes such as Minix A2 Airmouse and more.
- Added support for controllers and joysticks. (Xbox,PS3 & PS4)
- Removed purple highlight from Settings.
- libamcodec added & registered.
- Removed and cleaned up files / libraries that are no longer needed.
- Added Multi Webview options under Developer options / WebView Implementation .
- Fixed bug with keyboard "Enter" Key.
- Updated Gapps
- Added Google Clock.
- Added Android TV Remote Control.
- Alvatech Boot Logo & Boot Animation
- New Wallpaper
- Other changes, I'll add them as I remember.
If you would like to show a sign of appreciation. Please click on donation link down below. Thank you!
Donation Link Here
Notes:
Please read the "Extra Tips Section" on the 2nd post for additional help.
When box boots for the first time only, installation is still going on in the background please be patient for it to load completely.
When you connect the box to the internet for the first time google dependencies will need to be updated, please allow for these updates to finish.
Download ROM for SN: 95X2:
GTMini-A_AT_V2A_DRML1
Download ROM for SN: B95X:
GTMini-A_AT_V2A_DRML1_B95X
Installation Instructions:
Recommend Using Amlogic's USB Burning Tool. SD Card Method can be used.
Very Important! when you flash your box either by USB or SD-Card NEVER use the option Force Erase All only use the Normal Erase option or you will lose DRM Widevine L1 (Netflix Certification).
Click needed link down below to download.
USB Burning Tool Method: Amlogic's USB Burning Tool
SD Card Method: Amlogic's Burn Card Maker
1ST BOOT TAKES ABOUT 5-6 MINUTES, SO PLEASE BE PATIENT.
THIS DELETES ALL YOUR DATA SO DO A BACKUP IF NEEDED! USE THIS AT YOUR OWN RISK!
THESE BOXES ARE VERY PICKY IF YOU FLASH IMPROPER OR FLASH WRONG BOOTLOADER YOU CAN LOSE DRM WIDEVINE L1 OR EVEN DAMAGE YOUR BOX.
This is to share my work with everyone and to try to make these TV boxes more enjoyable.
I will try my best to answer or help with any questions and or concerns as soon as I can.
If something doesn't function properly please let me know with as much detail as possible and I will try to fix it.
I HOPE YOU ENJOY IT AS MUCH AS I DO!!
Thank you Beelink for the sample hardware.
To help support FreakTab you can purchase one of the following:
Purchase the GT MINI at Gearbest < click
Purchase the GT Mini-A at Gearbest < Click
Purchase GT Mini A 2 at Gearbest < Click
Originally posted by fmvg79 View Posthow can i save my original firmware before changing?
Thank you,
Alvatech
Hi Alvatech
SN: 95X2
On Netflix I'm getting an error.
I didn't Force Erase All but per below I'm on L3. I did flash this ROM over XTMOD-ATV X96 Max - GT1 ROM.
Can you tell the problem? Is there a way to get the box right?
Thanks!
UI-800-3 (207006)
From netflix "It typically points to a DRM issue. Follow the troubleshooting steps below to resolve the issue."
On my DRM info I assume this may be needed.
Widevine
Version v5.1.0-android
Sys ID 4445
Security Level L3
HDCP Level unprotected
Max HDCP unprotected
Usage Reporting True
Max 16
Number Open 0
Originally posted by txbut View PostHi Alvatech
SN: 95X2
Thanks!
UI-800-3 (207006)
Widevine
Sys ID 4445
Security Level L3
Max 16
Number Open 0
The only thing I can think of is either there was a force erase option that was done at one point while flashing a ROM or some files have been deleted or modified. I would try re-flashing the original GTMini-A ROM from Beelink with the USB burning tool and see what your DRM status is, it should be L1. If you still have L3 then there is nothing you can do about it anymore. Once you lose it there is no going back to L1. Not sure if somehow something else got flashed when you were flashing another ROM.
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
Edit: Welp, flashed GT1-mini_115N0.img and not knowing where to check for L1 I installed the Netflix's app through Beelinks app installer and Netflix is working. whew!Last edited by txbut; 11 September 2019, 02:25.
Hi Alvatech.. I just noticed from other GT1-A and GT Mini-A users that they will see error NWK 6-404 when launching Netflix ATV version. So I guess that's the end for Netflix HD/4K support on GT1-A and GT Mini-A, since I guess they managed to spoof Xiaomi build.prop and also using XIAOMI12TRIAL in the Netflix ESN key. Netflix managed to detect in the end and stop the streaming support on these models. However Netflix mobile version still works, but with SD quality, I think is better to stick with my Mibox S for Netflix HD streaming.
My question is, is it possible for me to downgrade the Google L1 to L3? I am thinking of using your firmware, set the option to force erase all flash while burning. Do you think it is possible?
Thank you.
Originally posted by azwandyazizan View PostHi Alvatech.. I just noticed from other GT1-A and GT Mini-A users that they will see error NWK 6-404 when launching Netflix ATV version. So I guess that's the end for Netflix HD/4K support on GT1-A and GT Mini-A, since I guess they managed to spoof Xiaomi build.prop and also using XIAOMI12TRIAL in the Netflix ESN key. Netflix managed to detect in the end and stop the streaming support on these models. However Netflix mobile version still works, but with SD quality, I think is better to stick with my Mibox S for Netflix HD streaming.
Thank you.
Yeah I've noticed it's all over Beelink's forum. There is nothing I can do about it. Beelink would need to be the one to resolve any issues people are experiencing, since their the ones who sold the box. I don't see any reason for you to change this box to L3, but yes that is one way to get it done. You should still be able to use the standard mobile version of the Netflix Apk. Not sure what Beelink is going to do now, I'm curious.
Thank you,
Alvatech
Originally posted by Rani2add View PostToday Netflix stopped working
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
Yep, it's all over Beelink's forum not sure what's going to happen next. I guess we'll wait and see.
Thank you,
Alvatech
and the best thing is, even gt1 mini firmware works on this..
thanks alvatech
Hi Alvatech.. yes, I managed to downgrade from L1 to L3.. using force full erase option using burnmaker.. the reason is one of my favourite streaming app is very lagging due to L1.. the same thing does not happen on L3 boxes.. so I think since this box no longer support netflix, why do i need google L1 anymore..
thanks alvatech
Thank you,
Alvatech
Okay, I guess it's time to see about making an Android 9 version for these boxes when I get some time. Since these have lost their certificate from Netflix then I can make one ROM for these boxes except for the ones with the new serial numbers.
Thank you,
Alvatech
I have another one GT Mini-A with B95X SN. Also do the same thing, except using 003P0 firmware. Managed to get the device now running on level 3, instead of L1.
Lesson learned the hard way. Dont trust any Chinese android devices for 4K/Netflix HD, unless it is Google certified. If I am not mistaken for android boxes, only 3 are certified from Google, Mibox, Nvidia Shield and Ematic Jetstream.
I don't expect Beelink to resolve this Netflix issue, unless they go extreme measures and pay big amount of money to Netflix.
LOL.
Good morning how are you?
I recently bought this TVbox for the advertising of netflix 4k, it worked fine but this month it stopped working for what I read in beelink forums and here the problem is general for all beelink gt mini-a
The concern I have is the following, when I made the purchase of the tv box I bought 2 the beelink gtmini-a (netflix 4k support) and a mecool km9 pro without this support, as I knew that the mecool had no support 4k look for an apk mod of netflix for android TV, it worked for me and it still works so far in 4k content without any problem
The problem is that when I install it on this beelink, you fail to know why that happens?
This is the link of the Spanish video tutorial where I got the apk.
apk link works smoothly and in 4k on tv box Mecool km9 pro
There are currently 3124 users online. 0 members and 3124 guests.
