it works on X2 CUBE, PLAY and PRO
Dear friends, I present to your attention my new hybrid for ATV lovers.
Many thks to UGOOS for sending me the Machine.
Based on stock firmware Ugoos X2
Why a hybrid? Anyone familiar with my ATV in past boxes knows, that I'm trying to combine both camps of amateur / opponents of AndroidTV. This is another step towards the perfect firmware, which AOSP supporters will also like:
1. All the benefits and convenience of the AndroidTV interface for Remote Control are present.
2. For those who like to work with a mouse, there is a Status and a Navigation bars, imperceptible for those who love the Remote, not the mouse.
3. You can also use the browser. An alternative TV-Market is installed in addition to the reduced ATV Market.
To increase the speed of work, and also taking into account only 2Gb of memory, I deleted everything that can be done without.
The Firmware is made in two versions:
- 1. img, for flashing via cable or using a specially prepared MicroSD (archive X2_ATV_by_Sasvlad_v....7z, inside the firmware image and file with MD5 checksum).
- 2. zip, for installation from TWRP-Recovery. Only for those who already have X2 AndroidTV by Sasvlad installed.
Changelog v.0.0.8:
- built-in modified for Ugoos X2Cube TWRP recovery 3.2.3-1.
Changelog v.0.0.9:
- Fixed device reboot when playing iptv
- Reworked CEC settings
- CEC. Added tv volume control settings
- Added hibernation function (Device Preferences -> Screen saver -> Power key action)
Changelog v.0.1.0:
- 1. Fixed some crashes when playing iptv
- 2. Added shownig CEC status (Device Preferences -> Display -> HDMI CEC)
- 3. Added volume regulator steps setting (Device Preferences -> Sound)
- 4. Added WebView switcher (Device Preferences -> Developer options)
- 5. Fixed default settings of CEC volume control
- 6. Fixed crash when trying reboot
- 7. ?hanged the default pink walpaper
- 8. Added background music widget
- 9. Added notification widget
- 10. Updated launcher and some GAPPS
Changelog v.0.1.1:
- 1. Added ability to set wallpaper to fit the screen
- 2. Added ability lock FullHD interface for applications that change display mode to 4k (Device Preferences -> Display -> Screen resolution)
- 3. Fixed S/PDIF passthrough work
- 4. Added power settings, silent boot settings (Device Preferences -> Power)
- 5. Other minor changes
Changelog v.0.2.1:
- 1. Fixed video rotation
- 2. Fixed video scaling higher than 100%
- 3. Added write permissions to external storages for applications
- 4. Fixed button loss for input devices settings
- 5. Added buttons MOVE_END, MOVE_HOME, F2-F5 for input devices settings
- 6. Removed camera event when double press the power button
- 7. Added default keylayout for g20s air mouse
- 8. Fixed air mouse microphone
- 9. Fixed switching audio tracks (passthrough)
- 10. Added DTS-HD and Dolby TrueHD passthrough support in Kodi, VLC
- 11. Fixed IPTV fps problem when starting a channel
- 12. Many other video codec fixes
- 13. Fixed waking up in different apps
- 14. Added new HDMI CEC options
- 15. Updated icons "Back", "Home", "Recents"
- 16. Fixed interface rotation problem if use quick panel button
- 17. Added USB Realtek Ethernet support
- 18. Removed TWRP Recovery
- 19. Other system stability changes
Changelog v.0.2.2:
- 1. Added disable auto power-on function (Device Preferences -> Power)
- 2. Some fixes and improves of system automatic frame rate function
- 3. Fixed video scaling higher than 100% for not 1080 resolutions
- 4. Fixed colored stripes bug when boot with interlaced resolution
- 5. Fixed Samba server when storage have damaged partition, unsupported fs or is it expanded internal storage
- 6. Added ext4 file system support for external storages
- 7. Improved Display size setting
- 8. Fixed dolby vision setting
- 9. TvSettings. Added rssi, frequency, link speed info for wifi connection
- 10. Fixed ethernet link down if enable VPN
- 11. Added ukrainian translations
- 12. Updated timezones
- 13. Added support of some usb devices
- 14. Added Android TV Remote Service
- 15. Added Air Screen as pre-installed application
- 16. Fixed cpu frequency problem
- 17. Fixed random power on
- 18. Other system stability changes
Changelog v.0.2.3:
From me an additional gift to all fans of X2 AndroidTV by Sasvlad: the long-awaited OTA update!
Who has already installed X2 AndroidTV by Sasvlad v.0.2.2, can now be updated from TWRP-Recovery in ZIP (pseudo-OTA) format.
Go to TWRP in any way, - Install - point to the file Update_AM6_ATV_by_Sasvlad_v.0.2.3.zip previously copied to the box.
Updating from the "Device Settings" will not work, only from TWRP.
- 1. Fixed CEC wake up
- 2. Added CEC work with function "disable auto power-on"
- 3. Improvements of system automatic frame rate function for more stable work with program AFR functions
- 4. Fixed video offset (black stripes), if use custom display size
- 5. Fixed colored stripes bug when boot with AV and on some old TVs
- 6. Replaced Android TV Remote Service to version from play market
- 7. Fixed bug, not showing all external storages for Samba Server
- 8. Added usb audio settings, removed USB audio routing from developer settings
- 9. Fixed CPU load with droidlogic app
- 10. DolbyVision disabled by default
- 11. Fixed "None" proxy setting
- 12. Fixed static ip settings bug, not showing current dns servers
- 13. Added custom ir power key setting
- 14. Some changes in deep color setting
- 15. Experimental function: Removed stock Youtube. Instead, an interceptor plug is installed on SmartYoutube.
To avoid duplication of voice search results, turn off search in SmartYoutube in the settings.
Changelog v.0.2.4 - v.0.2.5:
- 1. Picture optimization are disabled by default and added switcher (Playback settings)
- 2. Added experimental video picture settings (Playback settings)
- 3. Updated Velvet application, added Katniss application
- 4. Notifications from Android TV Remote Service are disabled by default
- 5. Enabled long press and double tap events for HOME button
- 6. Added confirm dialog to display color settings
- 7. Added some key layout files
- 8. Redesigned PowerMenu application. Now it is translucent. Added the ability to display its buttons on the main screen, assigning commands to buttons.
- 9. The new App Drawer, the appearance is improved for Android TV. Design borrowed from AmazonFire.
Changelog v.0.2.7
- 1. Fixed audio clicks in AV port
- 2. Added mouse settings to TvSettings
- 3. Added experimental ability use mouse as touch input
- 4. Video Picture Settings. Disabled system automatic frame rate function
- 5. Video Picture Settings. Fixed bugs of hue setting
- 6. Video Picture Settings. Removed sharpness setting
- 7. Video Picture Settings. Added setting for disabling all video effects and optimizations
- 8. Fixed some buttons in Chrome
- 9. SambaServer. Changed names of storages
- 10. Fixed crash of Bluetooth settings when device connected
- 11. Added support ext4, ntfs, exfat for SD cards in recovery mode
- 12. Added support ext4 for usb storages in recovery mode
- 13. Added support of multiple storages (partitions) in recovery mode if use System Update application
- 14. Fixed automatic update error with expanded storage
- 15. Fixed some crashes of System Update application
Changelog v.0.2.8+
- 1. Fixed mouse clicks bug
- 2. Fixed update from expanded storage if use System Update application
- 3. Fixed update from usb disks with multiple partitions in recovery mode if use System Update application
Changelog v.0.3.2
- 1. Fixed multichannel PCM audio problem. Added automatic detection
- 2. Fixed SPDIF work for 192 kHz 32 bit audio (AM6, X2)
- 3. Added high resolution audio support in user applications (sample rates higher 48 kHz)
- 4. Added PCM audio settings
- 5. Added SPDIF passthrough support when TV connected to AV
- 6. Fixed crash when exiting hibernation mode
- 7. Fixed returning to the same mode when use system AFR function
- 8. Added restoring last active display mode after HDMI hotplug event if possible
- 9. Added option for power on via Bluetooth (Device Preferences -> Power)
- 10. Removed CEC shutdown command when device reboot
- 11. Added option for power off related devices when going to sleep (Device Preferences -> Display -> HDMI CEC)
- 12. Changed some translations in TvSettings
- 13. Made TvSettings window translucent
- 14. Added top margin for Accessory window in TvSettings
- 15. Cifs, Nfs clients. Disallow enable client if not filled all fields
- 16. Changed default wallpaper
- 17. Added few wallpapers as preinstalled
- 18. Changed Wireless assistant settings, disabled fireasy by default
- 19. Added Ugoos remote server
- 20. Video freeze fixed for mpeg-4 videos.
Changelog v.0.3.3
1. Fixed work of multichannel high resolution PCM audio
2. Added saving display mode after turning off/on the TV with AV receiver
3. Now default display mode for applications equals resolution in settings
4. Now Lock UI size function worked for all display modes
5. Applications will not be redrawn if enabled Lock UI size function
6. Fixed screen rotation for non FullHD interface
7. Some wallpapers are copied to user folder
8. Added Fake Wi-Fi function
9. Fixed some crashes of application TvSettings
10. Added horizontal recent apps window as option
11. Fixed not worked TV volume control by CEC in some cases
12. Fixed h265 playback crash
13. Fixed interlaced video stream jitter bug
14. Fixed display freezes and becomes slow/lags while selecting PIP mode options in VLC app
15. Fixed freezes when playing 8k video (X3)
16. Ugoos remote changes:
- added quick connection menu
- added joystick menu
- fixed work with third-party keyboards
- added multi-touch to the touch screen
- added button on-off vibration
- added button power off TV box
- other changes
Dualboot build with CoreELEC
1. Increase CoreELEC partition size to 3GB
2. Replaced CoreELEC night build to stable 9.2.2
Changelog v.0.3.4:
1. Fixed middle portrait mode of screen rotation
2. Fixed audio passthrough for 2.0 TVs
3. Added new option for HDMI CEC when device turn off or standby
4. Added ability to adjust the volume of AV receivers via HDMI CEC
5. Some gamepads now work
6. Added ability to always use fractional frequencies for system automatic frame rate function
7. Enabled recent apps snapshots for TV ROMs
8. Changed appearance of grant permissions gialog
9. Changed volume bar view
10. Improvements for visibility of more Wi-Fi channels
11. Added dual band Wi-Fi hotspot
12. Added immersive mode option for system bars
13. Some fixes of focus for choice app window
14. Added Ethernet switcher
15. Now fake Wi-Fi option working without reboot
16. Fixed showing IP and MAC addresses when use fake Wi-Fi option
17. Other improves of fake Wi-Fi option
18. Updated ukrainian translations
19. TvSettings. Some descriptions changes
20. Fixed screenrecord utility
21. Changed boot animation (X2,X3)
22. Ugoos remote changes:
- bluetooth disconnections fixed
- connection status now available on server main page
- video streaming bug fixed
- some device pairing bugs fixed
- Wi-Fi/Ethernet connections stability optimized
Added the following applications:
- Opengapps Atv (at the very minimum)
- App Drawer
- Power Menu
- SmartYoutube
- Explorer X-plore, for remote
- Alternative Market AptoideTV
- GoogleChrome v.57. Do not update it, if you want to use copy-paste
Want to buy me a beer?
Donation Link Press Here or Here
Download:
- DOWNLOAD HERE THE X2Cube_ATV_by_Sasvlad_v.0.0.8
- MD5: 0005d9359e30881320955d06bfd7f0df
- DOWNLOAD HERE THE X2Cube ATV by Sasvlad v.0.0.9
- MD5: 72e492c77cdfae3d5139ab2504a35646
- DOWNLOAD HERE THE X2Cube ATV by Sasvlad v.0.1.0
- MD5: 29c624a0b7e711626a631018f654d878
- DOWNLOAD HERE THE X2Cube ATV by Sasvlad v.0.1.1
- MD5: 198eda3a5fca1e1884feab601098075f
- DOWNLOAD HERE THE X2 ATV by Sasvlad v.0.2.1
- MD5: 6c9dcaf32e58ba760f2acef25376bbe7
- DOWNLOAD HERE THE X2 ATV by Sasvlad v.0.2.3
- DOWNLOAD HERE THE X2 ATV by Sasvlad v.0.2.5
- DOWNLOAD HERE THE X2 ATV by Sasvlad v.0.2.7
- DOWNLOAD HERE THE X2 Android TV+CoreElec by Sasvlad 0.2.8+ Dualboot
- DOWNLOAD HERE THE X2 Android TV by Sasvlad v.0.3.1
- DOWNLOAD HERE THE X2_dce Android TV by Sasvlad v.0.3.1 DualBoot
- DOWNLOAD HERE THE X2 Android TV by Sasvlad v.0.3.2
- DOWNLOAD HERE THE X2_dce Android TV by Sasvlad v.0.3.2 DualBoot
- DOWNLOAD HERE THE X2_ Android TV by Sasvlad v.0.3.3 DualBoot and SingleBoot
- DOWNLOAD HERE THE X2_ Android TV by Sasvlad v.0.3.4 DualBoot
- DOWNLOAD HERE THE X2_ Android TV by Sasvlad v.0.3.6 DualBoot and SingleBoot
Install instructions:
- Use USB Burning tool 2.1.7.3
- Refer to Ugoos own tutorial how to flash this box!
Enjoy it!
Screenshots:
