[ROM] Ugoos X2 CUBE, PLAY and PRO ATV_by_Sasvlad ( AndroidTV 9.0 )
Originally posted by Sasvlad View PostUpdated: X2_dce Android TV by Sasvlad v.0.3.1 DualBoot
Unfortunatelly i have to move back to official Ugoos builds because HBO GO recognize firmware as rooted. Even i unroot first, reboot and install HBO GO still movies dont run. Application starts, but content cannot be watched.
Anyway, thank You.Last edited by Junoxe; 04 April 2020, 11:52.
Originally posted by lightsout View PostJust ordered an X2 Cube, looking forward to running this rom, anyone got a link to a cable for flashing, can I just use micro USB?
Also any problems running coreelec and android with only 16gb of storage?
Originally posted by Junoxe View Post
I dont have any problems. Just HBO GO doesnt show movies as recognize X2 Cube is rooted.
You could root with Magisk then delete the system/xbin/su file if it exists.
Follow the guide for Magisk here - https://forum.freaktab.com/forum/tv-...409#post795409
You also now need to enable 'Magisk Hide' checkbox in Magisk Manager's Setting.
Tried the Kodi HBO Go addon?
What i suffer most of Sasvlad and Ugoos firmware it is lack of simulated WiFi. It would solve problem. I had it in my previous Wetek boxes. That was superb.
And second issue (in my opinion) is unable to use WiFi and etherned connections in same time.
According to Magisk i'll try. But FakeWiFi disabling security in stock frimware and then i cannot watch HBO GO even on WiFi.
hello .
anyone use this rom in 4K? Do you have black screen blinking issues when playing video files? I explained my problem here: https://forum.freaktab.com/forum/tv-...very-5-seconds
thanks.
thanks.
You should ask Beelink for an update to fix your problem.
You could also try a better power supply & better quality hdmi 2.0 cable.
I don't think anyone has such problems since the device already went through 32 firmware updates and Ugoos would have fixed it with all their beta testers before firmware updates were released.
Finally got my box but I can't get the amlogic burning tool to detect my box. It works fine running Android Pie. But I want to flash this firmware.
I read the guide at the ugoos site. I also saw a video that showed I need to hold down the reset button when I boot the device to get it in the right
mode but that still doesn't do anything. I have tried on two win 10 machines and it won't work on either.
Can someone tell me the flashing process?
EDIT* I plugged in the hdmi and can see that I am in recovery mode, but it is not being detected.
There are currently 2057 users online. 1 members and 2056 guests.
