You have to press Start/Run in Amlogic burning tool then hold the reset button, connect the USB cable and then connect the power to the AM6.
[ROM] Ugoos X2 CUBE, PLAY and PRO ATV_by_Sasvlad ( AndroidTV 9.0 )
Are you using a USB-USB cable connected to the side OTG port?
Hi Sasvlad, the Dual Boot feature on this ROM is great work! Would it be possible to extend the CoreELEC partition where the user is using a Pro (32GB) device? For example could a Pro version of the firmware be created with a 16GB/16GB partition split between CoreELEC & Android? For these 32GB devices it seems a shame to have so much space dedicated to Android and a much smaller partition available to CoreELEC. Thanks.Last edited by Billyxyz; 08 July 2020, 12:12.
Originally posted by Arthur View PostCan someone help me?
I tested other rom and noticed that my mac has been changed to 02: 00: 00: 00: 00: 00. Please help me!
Originally posted by RiCkLaR_atvX View Post
Very RUDE to ask in several different custom ROM thread the Same question over and over, ask in the Proper forum thread that pertains to your exact ROM installed or your specific Device thread.
Thanks so much for this awesomeness. I am about to order an Ugoos X2 or X3 because of the possibility this firmware provides to dualboot seamlessly between ATV and CoreElec.
Just wondering for such a setup (and a Kodi library of maybe 1000 movies and 1 or 2000 TV eps) would one of the 2GB + 16 GB Ugoos boxes be sufficient or would one of the 4GB ram models (with 32 or 64 internal) be preferable?
Thanks very much!
(Posting the same question in the X3 ATV Rom thread too - any major performance diff between X2 and X3 ?)
Originally posted by kiboy6 View PostJust wondering for such a setup (and a Kodi library of maybe 1000 movies and 1 or 2000 TV eps) would one of the 2GB + 16 GB Ugoos boxes be sufficient or would one of the 4GB ram models (with 32 or 64 internal) be preferable?
Originally posted by anteros View PostCan someone extract the launcher and upload it to the mega.nz?
I like this hybrid with leanback laucher and Nav & status bar.
I need to install the launcher to x96s and a95x max.Any issues?
thanks.
If you are lucky enough to have an AndroidTV firmware for your device, the same launcher will be default anyway.
The navigation bar is because of changes in the firmware, nothing to do with the launcher app.
You can't install the launcher on stock Android since it needs AndroidTV firmware.
You're always so helpful.
I did flashed a rom with Nav & Status bar.
And I installed that rockchip ATV style launcher with mouse capabilities on S905Y2,everything works fine.
But only I don't like it's color.
What I really want the most is the A95x max+' launcher,but it's Android 9,I used Amlogic cutomization tool to extract the stock firmware,but empty in the system folder.
The customization tool is too old not updated by Amlogic anymore.
Any ideas where I can get this launcher?
And now for something completely different :) A95X Max Plus Amlogic S922X 4GB RAM 64GB ROM Android 9.0 (https://www.geekbuying.com/item/A95X-MAX--Android-9-0-TV-BOX-S922X-4G-64G-419526.html#utm_source=freaktab.com&utm_medium=referral&utm_campaign=elaine&utm_term=A95XMAXplus) 5G WIFI BT 4.2 1000M LAN Android 9.0 TV
There are currently 1492 users online. 3 members and 1489 guests.
