[ROM] Beelink GT1-Mini (and some others) VolksWare by Sasvlad Android 9.0
    [ROM] Beelink GT1-Mini Volksware v.2.0_by_Sasvlad (Android 9.0)
    Hi, I present to you another ROM for this box.
    I've made 4 different ROM's for these boxes two for boxes starting with SN: 95X and another two for SN: B95
    (English and Russian localization for each)
    Please download the correct ROM for your box.
    Changelog v2.0:
    • support for init.d is enabled
    • ancient Chinese busybox is removed
    • the newest busybox is installed
    • newest su binary is installed
    • Google ATV search (Katniss) and Google global search are installed. What to use, you can choose yourself.
    • installed SuperSu 2.82 patched, not requiring updating.
    • enabled USB debugging by default, full AdbShell support, disabled Selinux
    • Startup scripts are in the system/etc/init.d, on/off. at your discretion
    • changed Framework. Cut out the System Tray, but left the Navigation Bar
    • launcher central icons changed
    • firmware cleared of unnecessary files and garbage
    • default European time GMT + 2
    • 13 WiFi channels
    • TWRP already installed
    The following applications are added:
    • ES_File_Explorer_Pro
    • HD-VideoBox
    • Installed a program to manage the service Auto Frame Rate (afrd)
    • GoogleChrome v.57. Do not update it if you want to use copy-paste
    The second file in the archive is the md5 hash to check.
    Verified on the following devices:
    • - Х96Мах 4/32 и 4/64
    • - Beelink GT1 Mini (both revisions)
    • - T95Q
    • - Tanix TX5 Max
    Donations:
    Download:
    Patch for T95Q and X96Max to control the serial remote control ->
    (install with TWRP )
    https://drive.google.com/file/d/15W-...ew?usp=sharing
    Install instructions:
    • Use USB Burning tool 2.1.7.0
    • Refer to Beelink own tutorial how to flash this box!
    Enjoy it!
    Screenshots:
    Click image for larger version  Name:	Face.png Views:	0 Size:	619.3 KB ID:	780265
    Click image for larger version  Name:	Settings.png Views:	0 Size:	1,015.9 KB ID:	780266
    Click image for larger version  Name:	About.png Views:	0 Size:	957.8 KB ID:	780261
    Click image for larger version  Name:	DroidTV.png Views:	0 Size:	1,011.2 KB ID:	780267
    Click image for larger version  Name:	Pref.png Views:	0 Size:	960.7 KB ID:	780264
    Click image for larger version  Name:	White.png Views:	0 Size:	90.9 KB ID:	780263
    Do notifications work on this rom. Notification access has been removed from all android pie firmware on all android boxes. Not sure why, but all android boxes that I know of running android 9 have no way to view notifications. The notification panel is missing, and so is the notification access setting.
      Will it work on the Bqeel Android TV Box Y4 MAX [4G+64G] TV Box mit S905X2 Quad-core ARM Cortex-A53 ?
      I want to try but I have a feeling the wifi, bluetooth, and lan will not work like all custom roms.
        Tested with T95Q box.
        (download 95x version !)
        working: WIFI, BT...all apps...
        not working: Notification
        IR remote -> Patch for working Remote (TWRP)
        LED always on
        very fast boot....
        so for me the best Android 9 rom..
        good job by sasvlad
          IR remote
          LED always on
          very fast boot....
          good job by sasvlad
          Did you check to see if widgets were working? All the Android Pie roms for Android boxes are not only missing the ability to use notifications, but are also missing the ability to use widgets. Hopefully widgets are working for you, cause if they are then maybe a fix for notification access is not far off. The problem has been around for months, and either nobody seems to notice, or they simply cannot figure out what is causing it. I bought an Android Pie box not knowing about these problems, and the worst part is there are no Oreo roms for my box, so I am stuck with a box that has notification access or widget access. I have the A95X F2, and I wonder if someone could make an 8.1 rom for it? The A95X2 is scoring higher benchmarks than all of my other s905x2 devices. It is the only s905x2 device I have that uses DDR3 RAM, but it out performs all the DDR4 boxes. Its a great box, that does not have much of a following.
            @porkie:
            if u want widgets working, just install another launcher.
            4 me the widgets working with Square Home Launcher...
            screenshot:
              Hello,
              After shutting down , it can not turned on with the remote control,
              Must re-plugged the power plug to turned it on .
              and I'm using GT1-mini 4G/64GB with FW: GT1-Mini VolksWare by Sasvlad 95X English.
              thanks.
                hello how to get firmware for that one:
                model: C6
                ram:2gb Rom:32gb
                CSO: Mini smart projector
                Thanks.
                  model: C6
                  ram:2gb Rom:32gb
                  Thanks.
                  Ask the manufacture for your stock firmware, don't think anybody has started making custom firmwares for the Mini Projector devices. Good websites to start looking for stock firmwares is AndroidPCtv.com or Chinagadgestsreviews.com
                    Thanks.
                      Thanks! Sweet
                        Thanks, add on Tanix TX5 Max and with https://4pda.ru/forum/dl/post/169936...te_Sasvlad.zip. I using remote from T95Z Max. LAN ok, LED not ligts, think best rom I meet
                          tested and its working...
                          (only turn-on the box with remote is not working, but who cares... )
                          (big tnx to sasvlad)
                            Of course. I do not publish my work without a thorough check.
                              for me u are one of the best developer...
                              i hope its ok that i have uploaded your patch to google-drive.
                              (coz its hard to download from 4pda.ru without registration...)
