Is it possible to make this Rom so the front display works on the X96 Max. Rom works good but I cant tell if my box is on or off. thanks
[ROM] Beelink GT1-Mini (and some others) VolksWare by Sasvlad Android 9.0
Originally posted by bergerov View Postis not there. so I don't know how to do it.
I used an app from the play store called shortcut creator. You can make a homescreen icon using this app. When I created the droid settings I think I did have to change where the link pointed to, but I got it to work. I'm away for a couple of days, but if you have trouble I can explain better when I get home.
Originally posted by mojojojo67 View Post
Tested with T95Q box.
Download sasvlad95x version !
working: WIFI, BT...all apps...
not working: Notification
IR remote -> Patch for working Remote (TWRP)
LED always on
Originally posted by Sasvlad View Post
If you mean the clock, it does not show.
This firmware is great, but I need to know if my box is on or off.....guess that would be a hard thing to do.
Thanks SasvladLast edited by raruba; 07 October 2019, 15:30.
Originally posted by raruba View Post
Yeah thanks, I figured that....so that mean theres no way of knowing if the box is on or OFF. Thanks for the info
Thanks Sasvlad
I would love to try it on mine
Thanks, where did you get the LED from???
There are currently 42382 users online. 0 members and 42382 guests.
