[ROM] Beelink GT1-Mini (and some others) VolksWare by Sasvlad Android 9.0
Let me start by thanking Sasvlad for this awesome ROM!
1. Installed ROM on Transpeed TR99 X2 (4G 32GB)
2. Installed "Patch for T95Q and X96Max to control the serial remote control"
3. Installed "bootloader" provided in the "AndroidTV v.2.0 by Sasvlad Android 9.0" thread.
Everything is working flawlessly (WiFi, Bluetooth, Turning on/off device from remote control). The only thing that I noticed doesn't work is the Ethernet. The Transpeed TR99 X2 (pic attached) uses "Pulse H1102NL" Ethernet. I wish I know how to make it work or extract it from stock firmware.
If anyone has this device, I highly recommend installing this ROM if you don't use Ethernet.
Thanks again Sasvlad
Originally posted by bryan3r3 View PostLet me start by thanking Sasvlad for this awesome ROM!
Originally posted by Sasvlad View Post
You need to take the wi-fi chip driver from the stock firmware and add it here. Perhaps after that the Ethernet will work.
@Sasvlad
Hi All!
I was wondering if there is a way for me to recover my X96 MAX TV BOX (S905X 4Gb RAM, 32Gb ROM).
Unfortunatelly i had errors during the process and i accidentaly selected 'Erase all' while using usb burning tool twrp The result is that my box is not booting up and recovery mode is not accessible.
Thank you for helping.
Originally posted by sarppolat View Post@Sasvlad
Hi All!
You can return the stock Recovery.
In the root of the system folder, put the recovery-from-boot.p (-644) file for the appropriate revision. After rebooting, TWRP will be replaced by stock.
recovery-from-boot_95X.rar
recovery-from-boot_B95.rarLast edited by JBG; 14 September 2019, 22:20.
Sasvlad , could you please create a cifs.ko update? I am currently using this ROM but it does not support cifs manager and I want to mount a NAS drive to the system.
Could you please also add extended power menu with restart, as it is not available in the Developer menu.
Thank youLast edited by JoeGamer; 21 September 2019, 15:18.
There are currently 3667 users online. 1 members and 3666 guests.
