Many thks to Khadas for sending me the device to play
And many thks to trebor for be my beta tester
Ok guys im going to write the max i remember i did on sdk... i can't remember all of it!
Build from Latest source.
Debug Build ( i might do in the future a rls build with my own keys )
I also added my layout(in zip format in internal storage) for squarehome3, is not hard to import it, i will make a video on how to do it in the next days... or just search youtube i bet there is something explaining it!
NO RTL CHIPS SUPPORTED, it might work on some but not all... BT no RTL chips work at all.
Changelog *Fix*:
- Fixed TWRP...
- Fixed GT1 mini remote
- Organised remotes
- Added 3 more settings to build.prop
Changelog:
- Build From latest AML Pie SDK.
- TWRP
- NO ROOT (i do not root my roms sorry but you can have "su" in shell since is a debug build )
- Fixed a few issues present in latest sdk.
- Fixed CEC.
- Small change in kernel.
- LatinIme fixes and now can be used with remote DPAD
- Fixed force_land.
- Removed some "Null" pop ups
- Some additions and fixes to settings provider
- Modified DroidSettings, "More Settings" now calls white settings.
- Modified TVSettings, added "Display" to menu to call DroidSettings
- Added White Settings(regular android settings), and fixed lots of stuff
- Added squarelauncher3 and also added my layout to internal storage so you guys can import it from there if you like my layout of course!
- Added SetupWizard.
- Double click home brings up Recent Apps in Grid View.
- Long press home calls assistant
- Long press Mic Key in remote calls assistant ( only tested in Beelink King Remote )
- Long press menu to show navigation bar
- Added many KL's for many keyboards.
- Added Beelink King remote support. ( more to be added in the future )
- Added Provision.
- Added AndroidTV screensaver, by default will start in 1h you can change that in settings.
- Added AndroidTV remote control
- Added AndroidTV Assistant.
- Added some apps. ( not many since i don't like to add to much crap in my roms )
- Compilation done with optimizations.
- Changed system and vendor partitions size.
- Optimized lots of stuff.
- Gapps Nano, build from source already odexed from compile for a faster boot.
- Some small fixes to systemui.
- Enabled drop down setting from top bar but still needs some work!
- Noise filter set to 0, you can edit build.prop and set the one you want!
- Removed 1. boot pair remote page.
- Added 2 more remote to power on from sleep.
- Fixed Vulkan support.
- Fixed Navigation and Status bar.
- Reduced the time mouse icon stays on screen.
- Updated gapps again...
- Other small stuff done in sdk.
- I know there are more... i but i can't remember now, keeping a good log is not my strong at least when is not for my work place, lol!
Bugs:
- Of course there is bugs, there always be bugs....
Want to buy me a beer?
Download:
- DOWNLOAD HERE SuperCeleron.Multi-S905x2.Pie.Normal.20191004 *Fix* IMG
- MD5: 49A930DCA7F30F9DAF9F805B22691FA9
Install instructions:
- Use usb burning tool 2.1.7.3 to burn the IMG.
- More information on how to put the device in flash mode refer to khadas wiki!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
