[ROM] Generic SC MultiWiFi S905x2 Pie Normal 20191004 *Fix*
How can i fix the buttons on my rii remote, and i rember with my s905x i had to edit the keyboard config file, but i dont rember exactly what i changed (that was like 2 years ago lol)
on main screen and settings and in apps, none of the keys work, but while entering my info to sign into google, my IR rii remote works sometimes but no back button or home button (but BT one doesnt work at all)
BT doesnt even pair when using the droid settings "add accessorys" option. instead i have to go into the actual android settings to pair it, yet it still doesnt work
no luck with button mapper either
Does not support dual audio output via bluetooth (a stock android 9 feature)
Also, nova video player from the play store wont even open when installed, yet it works on my phone on nouget. Looks like I'm going back to an 8.1 romLast edited by huffmybrd; 22 October 2019, 13:43.
Originally posted by TheBlackening View PostHi Superceleron.
I installed this new ROM of yours on My Tanix TX5 Max, first glance really smooth and pleasant to work with.
Unfortunatelly WiFi isnt working (RTL8222BS)
I know , you mention it on the 1st page
but are you planning in adding support for that chip?
thanks in advance
When realtek releases a fixed build and give it to amlogic!
yes this is the non atv build.
[20:25:36 027][Global][Inf]--Update HUB6-3 \\?\usb#vid_1b8e&pid_c003#7&20905f02&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[20:25:36 027][HUB6-3][Inf]--Update device path
[20:25:36 027][Global][Inf]--Update HUB6-4
[20:25:36 027][HUB6-4][Inf]--Update device path
[20:25:36 027][Global][Inf]--Scan end
[20:25:36 065][HUB6-3][Inf]--Device is connected
[20:25:36 065][HUB6-3][Inf]--Close device handle 0x0000082c
[20:25:36 115][HUB6-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#7&20905f02&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000007f8
[20:25:36 166][HUB6-3][Inf]-------------Download DDR.USB-----------
[20:25:36 166][HUB6-3][Inf]--3-2-0-0
[20:25:36 166][HUB6-3][Inf]--Control write pll reg1 0xfffa0000:0x000000b1
[20:25:36 667][HUB6-3][Inf]--Control write pll reg1 0xfffa0000:0x00005183
[20:25:37 167][HUB6-3][Inf]--Control write pll reg1 0xfffa0000:0x000000b1
[20:25:37 668][HUB6-3][Inf]--Control write pll reg1 0xfffa0000:0x00005183
[20:25:38 168][HUB6-3][Inf]--Write initial succeed
[20:25:38 168][HUB6-3][Inf]--Upload encrypt at 0xff800228
[20:25:38 168][HUB6-3][Inf]--ulValue = 0xe0f83180
[20:25:38 168][HUB6-3][Inf]--Read encrypt value succeed
[20:25:38 168][HUB6-3][Inf]--Download DDR.USB,size: 65536!
[20:25:38 182][HUB6-3][Inf]--Transfer complete 65536
[20:25:38 182][HUB6-3][Inf]--Run at address 0xfffa0000
[20:25:38 182][HUB6-3][Inf]--RunInRam success
[20:25:38 227][HUB6-3][Inf]--0-0-1-8-0-1-0-0
[20:25:38 227][HUB6-3][Inf]--CheckFileRunState return 1-8
[20:25:38 227][HUB6-3][Inf]--G12 init
[20:25:38 227][HUB6-3][Inf]--Get Encrpt ulValue = 0xe0f83180
[20:25:38 230][HUB6-3][Inf]--Have Semaphore
[20:25:38 230][HUB6-3][Inf]--Download BL2
[20:25:38 230][HUB6-3]Aml_Libusb_bl2_boot2 start!
[20:25:38 233][HUB6-3]sequence= 0, datasize= 16384, fipOffset= 65536
[20:25:38 240][HUB6-3]sequence= 1, datasize= 49152, fipOffset= 393216
[20:25:38 246][HUB6-3]sequence= 2, datasize= 16384, fipOffset= 229376
[20:25:38 254][HUB6-3]sequence= 3, datasize= 49152, fipOffset= 81920
[20:25:38 279][HUB6-3]sequence= 4, datasize= 16384, fipOffset= 65536
[20:25:38 287][HUB6-3]sequence= 5, datasize= 49152, fipOffset= 393216
[20:25:38 293][HUB6-3]sequence= 6, datasize= 16384, fipOffset= 229376
[20:25:38 301][HUB6-3]sequence= 7, datasize= 49152, fipOffset= 180224
[20:25:38 319][HUB6-3]sequence= 8, datasize= 16384, fipOffset= 65536
[20:25:38 326][HUB6-3]sequence= 9, datasize= 49152, fipOffset= 393216
[20:25:38 331][HUB6-3]sequence= 10, datasize= 16384, fipOffset= 229376
[20:25:38 339][HUB6-3]sequence= 11, datasize= 49152, fipOffset= 245760
[20:25:38 392][HUB6-3]sequence= 12, datasize= 16384, fipOffset= 65536
[20:25:38 398][HUB6-3]sequence= 13, datasize= 49152, fipOffset= 393216
[20:25:38 403][HUB6-3]sequence= 14, datasize= 16384, fipOffset= 229376
[20:25:38 412][HUB6-3]sequence= 15, datasize= 49152, fipOffset= 245760
[20:25:38 464][HUB6-3]sequence= 16, datasize= 16384, fipOffset= 65536
[20:25:38 470][HUB6-3]sequence= 17, datasize= 49152, fipOffset= 393216
[20:25:38 475][HUB6-3]sequence= 18, datasize= 16384, fipOffset= 229376
[20:25:38 483][HUB6-3]sequence= 19, datasize= 49152, fipOffset= 442368
[20:25:38 507]BL2 report Error, code= 32
[20:25:38 507][HUB6-3]cmd error, cmdType:43984
[20:25:38 507][HUB6-3]Aml_Libusb_bl2_boot2 end!
[20:25:38 507][HUB6-3][Inf]--Release Semaphore
[20:25:48 636][HUB6-3][Inf]--Detect Device remove timeout
[20:25:48 636][HUB6-3][Inf]--Device is connected
[20:25:48 636][HUB6-3][Inf]--Close device handle 0x000007f8
[20:25:48 687][HUB6-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#7&20905f02&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000954
[20:25:53 737][HUB6-3][Inf]--0-0-1-8
[20:25:53 737][HUB6-3][Err]--CheckFileRunState failed
[20:25:53 752][HUB6-3][Err]--[0x10303004]Romcode/Switch status/Identify/Error result
[20:25:53 752][HUB6-3][Inf]--Close device handle 0x00000954
[20:26:00 727][Global][War]--User click stop button
[20:26:00 728][Global][Inf]--Enable burning 0
I tried two different ROMS from this site, the Generic and the ATV with no luck.
It seems that its a common error but I'm a little rusted, will you be so kind to help me?
Thank you.
Arthur from Argentina.
Originally posted by arturojgt View Post
Hi Superceleron. I'm using the 2.7.1 burning tool and your generic rom for the KM3. The burning tool recognizes the unit but I having trouble at the 3% - UBOOT with the following error in the log:
It seems that its a common error but I'm a little rusted, will you be so kind to help me??
Thank you.
There are currently 4009 users online. 3 members and 4006 guests.
