[ROM] Generic SC MultiWiFi S905x2 Pie Normal 20191004 *Fix*
Originally posted by TaperChuck View PostThis will probably be the next firmware I try in an attempt to get HBO Go sound working on my GT1 Mini.
Anybody know if it work with this version? I'm finding I prefer the "normal" non-ATV firmware's on this box when using the stock remote control.
Hi SuperCeleron
I put this on my Bqeel Y4 MAX. It is a u218 s905x2. I am now stuck at the AndroidTV powered by SuperCeleron Logo. I have tried to re flash with USB Burning Tool. But The device does not get recognized. No HUb is seen. Tried the reset button. ANy clues on how to get this thing unbricked?
Grovvey 58
Grovvey 58
Well i can only think is you try to put it in mask mode!
Search around the forum i think there's a topic on that!
Can you tell me how add my t95q remote control? i know that must be in vendor/etc the remote.tab file but im not sure what more change to load that tab file in boot, i have the tab file needed for the t95q, im developer too, i need your help to add that tab file to fix my remote control, thanks
Originally posted by juliotec View PostCan you tell me how add my t95q remote control? i know that must be in vendor/etc the remote.tab file but im not sure what more change to load that tab file in boot, i have the tab file needed for the t95q, im developer too, i need your help to add that tab file to fix my remote control, thanks
Just remove in vendor/etc the remote.tab1 and rename yours to the exact same filename, who and dont forget inside you remote.tab1 this should be like this "custom_name = amlogic-remote-1"
well i already put away this sdk since i will be rls a new one, with support for s905x2 and s905x3 all in one... so let me see if i can remember...
Hello superceleron, thank you very much for your rom. Thank you for your hard work. I flashed your rom with x96max 4/64 s902x2 TV box, the box indicator light is off, the infrared remote control is not working, and the remote control return button with receiver is Can't use, now I want to flash back the original firmware of x96max, the computer can't detect the TV box, please brush your ROM and then flash other firmware
Originally posted by danshui View PostHello superceleron, thank you very much for your rom. Thank you for your hard work. I flashed your rom with x96max 4/64 s902x2 TV box, the box indicator light is off, the infrared remote control is not working, and the remote control return button with receiver is Can't use, now I want to flash back the original firmware of x96max, the computer can't detect the TV box, please brush your ROM and then flash other firmware
let the box boot to the system and then (i hope you flashed the Debug build) install terminal emulator to the box connect the usb cable to the usb port and type in terminal emulator "reboot update" (without the "") and wait until it shows in the usb burning tool..
hmmm
There are currently 3008 users online. 0 members and 3008 guests.
