A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Guest
This is what my box came with, should be factory firmware, but look thru these... https://androidpctv.com/a95x-f3-firm...pdate/
Originally posted by masher17 View PostThis is what my box came with, should be factory firmware, but look thru these... https://androidpctv.com/a95x-f3-firm...pdate/
Guest
Originally posted by brajamohan View PostHi friends, please help me , my box A95X F3 RGB box got bricked,.
it doesn't turn on ,only blue light glowing inside..
I cant flashing firmware even pressing the reset button, it doesn't detecting device in UBT, please help anyone....thanks
I usually apply the firmware without difficulty;
1) Windows 10 USB PC,
2) USB BURNING TOOL (USB_Burning_Tool_v2.1.7.1),
3) Erase Bootloader UNMARKED,
4) Select the firmware,
5) I click on start,
6) I don't use the power supply,
7) I connect the USB cable to the PC,
8) Connect the USB cable to the A95X F3 (rear port),
9) UBT recognizes and starts to apply the firmware.
10) Success!
NOTE: I do not press the reset button.
10) Success!
Hi,i just bought this box and i am new to android tv boxes.I see many of you put custom roms on it.I have read on another forum that the atv 9 rom is pretty good.Sorry for my stupid question,but what are the biggest advantages when putting the atv9 rom on it compared to the stock rom?I have the a95x f3 air and would like to know more about procedure of installing the right atv9 rom on it.Sorry once again and thank you...
There are currently 1508 users online. 0 members and 1508 guests.
