A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Guest
Young Guest .
Does the same company that manufactures and / or distributes the A95X F3, have an equivalent with a gigabit network?
Note:
I received my Tanix TX6s.
I'm enjoying it, but the launcher is very restrictive in relation to customization.
I'm having problems with Prime Video and Skype.
I have already placed a request for help on the appropriate topic.
Guest
Note:
box...Buy the Nvidia Shield I own one its by far the best box out there, it has the gigabit Ethernet LAN
Originally posted by masher17 View Post...Buy the Nvidia Shield I own one its by far the best box out there, it has the gigabit Ethernet LAN
$199,99 :-)
Grateful for the answer.
In reality, I am satisfied with something simpler ...
I have a Beelink GT1 that suits me very well.
I am hoping to start selling TX5 Plus at stores like Gearbest.
Good weekend.
Note: I believe that the equivalent of the A95X F3 with 1,000M of network is the X96 MAX PLUS.
Hi guys.
I received this tv box a95x f3 4/64gb and first impressions are mixed. It is working ok but I have to problems. The notification bar is not accessible with the mouse cursor, I mean it does not appear when I drag down the mouse cursor so instead I have to use the keyboard combo win+N to make it appear bus still I cannot click on the items or clear all the notifications. How garbage is that ?
Also the mouse cursor is so huge it drives me nuts. I tried to use dpi changer but I had not success it is still bad.
What can be done ? Is there a solution ?
Also is the stock firmware the best option or is there a better custom firmware to replace the stock os ?
Guest
Originally posted by masher17 View PostThere has been a system update for my A95XF3 to 2020 0612-1351 has anyone tried it yet?
-the links are all MEGA download links, so easy to download.
Originally posted by webipsum View PostPlease:
What is the TWRP to perform on boot recovery to back up and restore the A95X F3?
Note: It is not for applying the firmware. It is for backup and recovery only.
Thankful.
Boot to recovery and choose this file you downloaded.
(The easiest way to boot to recovery is to install "Terminal Emulator" and then to just type "reboot update").
Good luck.
Guest
Guest
There are currently 4389 users online. 1 members and 4388 guests.
