A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Originally posted by Scarface911 View Post
Do you have any idea how to recover boxes using sd sd card?mine doesn't boot anymore after I forced shutdown it
Maybe there is posted in this or another thread which the pins are to short for the A95X F3
Originally posted by Jancales View Posthttps://www.getdroidtips.com/downloa...rn-card-maker/
You need the OTA zip file, the follow instructions in this link
The instructions in this website are for burning the .img file, I already tried that the box doesn't boot
I was confused, because I alweays use Burning Tool, and thought Bootcard maker used the zip file instead of the img to make the S card
So if it doesn't boot into recovery anymore your only option is using Burning Tool and get the box in mask rom, as explained in my other post
No they are not for burning the image, burning the image is done connected to your PC and using Amlogic burning tool, and not with booting from a SD card as explained in the link.
Im sorry but I think the 2 links are the same
This is boot card maker, which boots from SD card
This is Amlogic Burning tool, which is done by connecting your box to your PC using a USB cable
Im talking about these 2
Why the forum software added the link twice I don't know
Originally posted by soldiaz View PostSehe ich auch so! Ich habe auch eine custom rom und bei mir läuft sogar triple wlan jetzt! Außerdem klappt das mit bluetooth mega mäßig - ich glaube die box ist wie gebeamt jetzt, ultrakrass mit Android TV 10!!!!
würdest Du bitte Deine Erkenntnisse an mich weitergeben?
Ich bin an der custom rom sehr interessiert und an der Vorgehensweise zum Flashen.
Für Deine Unterstützung wäre ich Dir sehr verbunden!
Guest
Has anyone installed the new system update 2020 03 06 1700 ? I am still using the 2019 11 25 1551 was wondering if i should update cause it works really well as it is now.
There are currently 2840 users online. 0 members and 2840 guests.
