I can't click on anything can't click and drag on Nova launcher can't navigate in games something is up with my mouse on this box anyone know a fix!!
A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Hey does anybody know if there's a way to pull down the notification bar when I boot it up I did see it there but then it disappeared now I can't get it back!??? Also does anybody know how to fix the the mouse problems and change the size of it?
I can't click on anything can't click and drag on Nova launcher can't navigate in games something is up with my mouse on this box anyone know a fix!!Last edited by @RickyBush_; 06 December 2019, 19:57.
Originally posted by @RickyBush_ View PostI can't? click on anything can't click and drag on Nova launcher can't navigate in games something is up with my mouse on this box anyone know a fix!!
Originally posted by RiCkLaR_atvX View Post
Stop using Nova Launcher! It is not correctly formatted for Android 9 Pie, use a better launcher app.
Guest
Originally posted by @RickyBush_ View Post...its something to to with this damn rom I want? the pull down notfinotifics as well...
try this:
If u dont have a Navigation or Status bar in your stock or custom rom u can try this one from playstore... works for me... :) Notification/Status Bar: https://www.google.at/url?sa=t&sourc...iUnpoevdBFL_F4 (https://www.google.at/url?sa=t&source=web&rct=j&url=https://play.google.com/store/apps/details%3Fid%3Dcom.
Originally posted by @RickyBush_ View PostIt's not just Nova launcher its something to to with this damn rom I want? the pull down notfinotifics as well? but need a mouse fix or just a whole new rom
Why most the experts here on FreakTab will only recommend device Brands that offer support (i.e. Ugoos, Beelink, Khadas) and actually test the equipment+software they sell. A95X is not a good brand, no software support, no forum, no contact website, they don't listen to customer feedback; overall if you choose to buy A95X devices you can expect tons of problems. Ugoos, Beelink, Khadas are sometimes double the price of the cheap TvBox's but you get what you pay for in those other cheap devices.
Yes, every TVBox enthusiast already knows Amlogic standard SDK has the software bug for Android 9 that Notifications+StatusBar doesn't work properly. This can be corrected of course by hacking the system apk software code. Most developers though will skip wasting time on such a shit brand like A95X.
Hope someone will make a rom though (fingers crossed emoji)
Can I copy any past the mouse settings from my h9+ pro to this box with the root explorer (thinking emoji) haha
Originally posted by @RickyBush_ View PostCan I copy any past the mouse settings from my h9+ pro to this box with the root explorer (thinking emoji) haha
What mouse settings do you refer too? As far as I know those are hard coded into the framework, which can be merged if you decompile firmware and switch them out, of course both firmwares must be Android Pie, and then Flash new firmware with USB Burning Tool.
Originally posted by @RickyBush_ View PostHey does anybody know if there's a way to pull down the notification bar when I boot it up I did see it there but then it disappeared now I can't get it back!???? Also does anybody know how to fix the the mouse problems and change the size of it?
you can move the notifications bar when you get a boxed message from WhatsApp, Facebook Messenger, you will read the message and then you can access the notifications bar until you unboxed again, it was the only solution I know
Launcher
On Android 9 Nova launcher doesn't work but it's not a problem as you can use a much better was launcher And with this launcher you can place a widget on the desktop to pull the notification bar down but to interact with the bar only using the method I refer to above
I hope I helped if anyone has any other suggestions I share
Originally posted by krazeus View Post
Notifications
Launcher
There are currently 3292 users online. 0 members and 3292 guests.
