A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Originally posted by krazeus View PostIt freezes what you are doing in the TV box and after 3 to 5 seconds restart
It happens even without opening any app
Tried with root on and off
Originally posted by krazeus View PostMy variant is f3, and I already see the temperature and they're below 50c
Can you post tor ex. From cpuz the specs so we can be sure that you indeed have the F3 and the shop where you bought it send the exact model in your case the F3 and not the air?
Also have you tried any other psu 5v2a because you could have a faulty psu with the box freezes and restarts as you said.
Don't be offended i im just trying to exlude any possible reasons.
Originally posted by aeolous View Post
Which app do you use to monitor the temps?
I use cpuz to see the Temperature and model and you confirm the above information
Box I bought at banggood
Originally posted by hedehede81 View Post
after you factory reset, it does this? or you install some apps then it does this?
I bought and received the same day the two A95xf3 boxs And only one is giving the problems I mean, the other works beautifully
Originally posted by krazeus View Postfirst thing I did was test with another charger from the other box because I bought 2 equal
I always change the heatsink and the thermal pad in any box that i get from time to time,and i am also waiting a A95X F3 from Banggood
Originally posted by krazeus View PostI have already done factory reset and rom installation by PC without any app installed and the problem continues
Guest
hedehede81 yes i updated the ROM yesterday, it was hooked up to a TV that the sound bar was malfunctioning so i thought it had a sound problem. And it is working fine now.
I don't know what is new with the update yet.Last edited by Guest; 02 December 2019, 02:08. Reason: Had wrong information, audio is working fine.
Hi Please, help ME. I bought a LEMFO A95X F3 AIR two days ago. Now, it doesn't start again. It goes to REBOOT permanetly.
I red all this topic, but i do not find how to solve this situation. In my box there is not a "reset button" in the chassis, so I do not try to make a "reset" as in the link posted from Rajan2002 . I tried also with the only micro sd card, but it appends nothing.
Please, help me
There are currently 2730 users online. 1 members and 2729 guests.
