A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Originally posted by aeolous View Post
Seems to me that you have an overheat problem if you 've got the A95X F3 Air variant probably, check the temps fyi there are 3 variants that i know of
I was gonna order the F3 but currently there seem to be some stock issues, which make me consider going for the F3 Air instead.
I thought the only difference between them is the Nand chip, so why you think the Air would overheat and the premium model not?
Hello
I got a a95x f3 that doesn't boot (only red light), I tried flashing it with stock fw but it always gives error, tried different cables different fws but same problem, I would like to try the sd method but I don't know what files to put there,for now I just got img files,any help would be appreciated.
Originally posted by Scarface911 View Post
Yes it does run hot 66~78°
Since I live in a tropical country, I then don't even have to think about ordering it, as it will here run even a few degrees hotter
Originally posted by Jancales View Post
Thanks for the confirmation, when I looked at pictures of the internals that is what I suspected.
I've read in some forums that it's fixable by replacing the heatsink with a larger one,the heatsink is pretty small in this box
In the past I have built fans underneath boxes, but lately I use the M8S Max which has a fan built inside and stays below 50c here. On idle 39c, no modifications needed, which is always risky.
From the reviews I read here and elsewhere I have also not found a S905X3 box that doesn't have issues, and there very little available in custom roms also.
So for now I'll stay with the M8S Max.
I have modified loads of boxes, and yes a larger heat sink will improve things, but a box that runs those temperatures needs a fan to get to 50c.
There are currently 3821 users online. 0 members and 3821 guests.
