A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB
Originally posted by KayaBahadir90 View PostHello again.
I tried to flash ROMs with micro SD option. I used burn card maker program and tried both stock img and that custom img ROMs. The flash process didn't start whatever I did. I used a stick and pushed reset button and applied the steps. On the TV screen only for a half seconds "upgrading" text seen and then lost. If I hold the reset button the text comes and dissappears constantly.
I also applied the same things with another micro sd card and also a USB flash drive. No solution.
What I am doing wrong? Or can be device is defective? Or are there any other solution to start flashing process other then reset button?
EDIT: NOBODY GIVE AN ANSWER FOR 10 DAYS! WHAT A HELPFUL FORUM AND USERS HERE!
I had to find my own solutions by trying. I WON'T explain them here.
Originally posted by hedehede81 View Post
I know how to turn off root. I ask if it is possible to leave root on and to have a popup asking "do you want to grant root access to this app?" Right now, any app is granted root access without asking user.
Guest
Have you tried APKPure and that version there of Disney + app is V2.2.0-rc5...sometimes I've seen updated apps in there a lot.
There are currently 2741 users online. 0 members and 2741 guests.
