Spotted in the wild: x88 King x922
Hi, i will ask mr. Slimhouse and Vortex for help on coreelec. This box have issue with 1gbit speed of lan on coreelec. Under coreelec this tvbox going only with 100 mbit mode. It is same situation than with oficial android build from manufacturer. If somebody know, what must be changed, please add energy to solution in this topic: https://discourse.coreelec.org/t/s922x-x88-king/7633 thank you!
Originally posted by atirage21 View PostHi, i will ask mr. Slimhouse and Vortex for help on coreelec. This box have issue with 1gbit speed of lan on coreelec. Under coreelec this tvbox going only with 100 mbit mode. It is same situation than with oficial android build from manufacturer. If somebody know, what must be changed, please add energy to solution in this topic: https://discourse.coreelec.org/t/s922x-x88-king/7633 thank you!Last edited by darkstar; 21 June 2020, 11:07.
Guest
Originally posted by greenstone View Post... trying to find a good link to x88king_aosp_vtx_v2.4 ...
Originally posted by miziou View PostHi guys - asking for a friend of mine - is it possible to flash Slimbox 5.1 using Burn Card Maker? Or better not and stick to USB Burning Tool?
The box to flash is X88 King (s922x)
Thanks in advance!
Originally posted by raruba View Post
I would use the USB burning tool 2.1.7.3 works good.
USB Burning Tool use is clear, but would it work to flash this rom via Burn Card Maker?
Situation is I don't have physical access to the box and I would like to help a friend flashing his box for the very first time.
Yesterday we wanted to go with the procedure over the phone, but he didn't have a male-male usb cable, so I thought I'd ask here about Burn Card Maker and guide him with the process
My gut tells me to go only with USB Burning Tool, but now I just wanted to know out of curiosity
Cheers!
There are currently 4467 users online. 1 members and 4466 guests.
