Spotted in the wild: x88 King x922
Guest
Originally posted by BowerR64 View PostHere is one link i saved im trying to find the link i found that had every version, i Downloaded most of the versions and tried em all
https://drive.google.com/drive/folde...1dSHLpEgXD6EC8
Maybe that link has the rom versions on it just need to click back?
older versions
https://drive.google.com/drive/folde...Azwpwcztk0GLri
I dont remember there being a 4.3
https://mega.nz/folder/Bbwh0aQJ#iNVS...older/4OgRGTJb
The other old versions links dont show which tvbox they are compatible with
Originally posted by peybolman View Post
In the first link there is no one for X88 king.
This is how i thought it worked, first you start with a working rom, say stock rom that came with the box, you use twrp and you install the slim rom which just "patches" the stock rom with the slimbox modifications? The slimbox rom isnt a stand alone rom thats why it needs a working rom to start with then it makes all the changes deletes the crap bloat ware apps you dont use, changes how the settings work, adds apps that we actually use and cleans things up
Then you add the "vendor" file that adapts the slimbox rom to your spacific box say the "X88" that has the "drivers" like the chipset, wifi, bluetooth etc.
Is this not how it works? or am i confused?
SO when you say it doesnt list what box its for, its just part of the whole rom, its like a 3 part procedure #1. start with working rom, #2 decide what Slimbox version you want 4.1, 4.2 5.1 etc #3. install vendor that completes the rom into a total complete rom?
Stock rom>Slimbox>Vendor
Least thats how i thought it worked?
I installed slimbox ver 4.3 ATV UBT and it works fine. I didn't install anything sooner or later. As I wrote earlier, ver 5.1 is not functional on our boxes.
https://drive.google.com/drive/folde...ZamioCVs8x8Con
and here is the supplier along with the ROM and you do not have to do anything extra and if I am wrong please correct me
Originally posted by artpaw View PostI installed slimbox ver 4.3 ATV UBT and it works fine. I didn't install anything sooner or later. As I wrote earlier, ver 5.1 is not functional on our boxes.
that is why I ask for a zip rom 4.3
Originally posted by mAtvXk View PostThere's no SLIMBOX zip version available for x88 King, only as img ROM.
I found this but it looks quite difficult...Is this the only way to get it done?
https://forum.xda-developers.com/and...files-t3598139
Does anybody know any other place where it explains how to do it? Or an easier way?
Just a question to see if more of you have this issue...
after tvbox is working for sometime cpu use is high. Checking what process is being the reponsible I found that system/bin/netd starts consuming 100% CPU time infinitely
By the way I had the issue with slimbox 4.3 also 5.1 and others I tested before
it looks that this problem happens also to other people
A guy states that the problem is in the code parsing netlink messages, which is used by netd. It seems that netd gets stuck in infinite loop as soon as it receives buggy netlink message.
Does anybody know a posible solution?
SLIMBOX ver 6 for X88 King
ATV and AOSP for UBT
Android 9
4pda: https://4pda.ru/forum/index.php?show...post&p=9652549 9
Telegram channel: https://t.me/slimbox_x3_x2
Download: https://drive.google.com/drive/folde...xy?usp=sharing
Changes:
• Cut ViPER4AndroidFX (can be installed with a patch)
• Changed soundbar
• New logo and loading animation
• Activated by default the dark theme of the system
• Updated firmware
• Working built-in AFR
• Removed unnecessary launchers (AOSP)
• Added recent as atv,
so the close all (AOSP) button does not work
• Recent displays preview pictures
• Disabled additional image settings
• Updated wallpaper pack
• Voice search in Russian (AOSP)
• Cleared the firmware from debris
• The minimum number of built-in programs
• Status bar and navigation are hidden by default,
activated in settings
Originally posted by peybolman View PostJust a question to see if more of you have this issue...
Does anybody know a posible solution?Last edited by atirage21; 28 July 2020, 20:31.
Android 9
Changes:
• Changed soundbar
• Updated firmware
Update: No change on v6.1, some apps still don't open.Last edited by raruba; 29 July 2020, 14:38.
There are currently 5272 users online. 0 members and 5272 guests.
