Spotted in the wild: x88 King x922
Originally posted by destripa View Post
What applications are not working? I would like to try
Originally posted by SlimHouse View Post
Hello...
Since I finally managed to flash this "X88 King" (very special part, Beelink & Co are a lot easier) with the current Slimbox.
I still have a question, but about TWRP. Actually works quite well, only since flashing the Slimbox 7.1.7 in the TWRP menu (via USB stick) I can no longer select from which source I want to install something. ONLY the internal memory is selectable ... Before this worked fine.
The ATV patch cannot be installed either, and it aborts with an error message. Unfortunately I couldn't read, it went too fast ...Maybe someone knows a little more ...
Thanks, Camleot631
I have installed it and the screen works fine, for now I have not seen any problems, then I have installed the AOSP patch and the screen shows load continuously. Thank you very much for your work
Ops meant to say v4.3Last edited by raruba; 23 August 2020, 12:53.
Thanks, Camleot631
you have to install TWRP 3.4 first
TWRP AML SlimHouse 3.4.0_3
https://mega.nz/file/oLIQRKiB#Mqh60A...pD9ZED23xqow54
Originally posted by peybolman View Post
I think the issue is that you are using the TWRP that came with the rom.
What I also noticed (with the Slimboyx ROM) is that the "X88 King" does not keep the clock on the display in standby mode. Maybe this is just a different setting, but I haven't found anything ...
Guest
Originally posted by mAtvXk View Postproject SLIMBOX [xda-developers.com] ;-)
Update X88 King...lots of apps don't work (Zion TV, Tubi TV, and ES File Explorer) on this version...actually some apps haven't worked since SlimBox v4.3 and Vortex v2.4
Going back to SlimBox v4.3, its the best for me. Alos like Vortex v2.4
And its the same for the X3 Boxes (x99 Max+, H96 Max, X96 Max+ and A95X F3) also...the v7 and 7.1...lots of apps don't work, at least I can't get them to work. ES File Explorer would even install apps, says SD card not found.
The old System v4.4 for the X3 boxes is the best one I have used.Last edited by raruba; 27 August 2020, 14:00.
I tried last xvortex rom in version 7. First issue: many things was only in russian or sometimes english language. My slovak language in android was broked. Second issue: it is not possible change twrp from vortex to version from slimbox, which have support for many language in twrp.
There are currently 2797 users online. 1 members and 2796 guests.
