NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
thx
my stick named mk809iii,and i flash the rom of T010_publice_root_AP6210_20130905.img,it works well,and i also flash the finless1.5 bellow:http://pan.baidu.com/share/link?shar...fid=1384876162,it also works.hope be helpful.
1000Thanks Neomode for the latest rom... It boot fast and works fastest than any other rom!
Wifi connects and works fast... My CX-919 Now finds the wifi routers immediately.
Netflix works faster without any freeze, 10 time better than with Finless Roms...
The video image Quality is excelent, crisp and neat... Without jaggies!!!
I on have one little problem with the total Memory available for APPs...
I flashed my CX-919 2GB/8GB without problems, but only got in setting/Storage/Internal Storage:
TOTAL SPACE= 0.98GB
NAND= 5.22GB
I previously have used Finless roms and always got a 3GB Total Space...
How or where can I configure to get 3GB for APPs with this ROM?
Thanks in advance!
Originally posted by ulises1954 View Post1000Thanks Neomode for the latest rom... It boot fast and works fastest than any other rom!
TOTAL SPACE= 0.98GB
NAND= 5.22GB
Thanks in advance!Please consider making a Donation to freakTab
Originally posted by blinkone View PostYou can use the finless parameter file from the finless rom when you flash it... I think you can choose from 1,2,4 or 6GB parameter
You mean that I will have to replace the parameter file that came with this 1.7 ROM with the Finless One?
And flash again with the finless parameter file?
Could you please let me know the name and location of that file?
And flash again with the finless parameter file?Please consider making a Donation to freakTab
Originally posted by blinkone View PostYes that's right its quite simple to do.In the flash tool on the far right hand side of the parameter file there's a small box click in that box to locate your finless parameter where its stored on your pc & reflash..
Neomode don't know if it is to much to ask for, but could you please make a parameter file with the 3GB?...So I can download, replace the original one, flash my CX-919 and finally get the Total 3GB Memory for APPs?
Originally posted by attobytes View Postparameter file for 8GB would be greatly appreciated if it's not to much to ask?Please consider making a Donation to freakTab
Thank you
Thank you for the ROM. It is working well on my MK802IV. SixAxis is working fine - the bluetooth MAC address changed from my previous install but after I updated it via pairing tool on PC it connected right away.
My wifi is bad - this is not the fault of the ROM, just the terrible design of the stick. I wish to use my USB wifi dongle which uses AR9271 chipset, can anyone help me with a .ko module ? OR, is there a USB wifi dongle that is already supported by this ROM which I can buy ? Does Miracast/Wifi Display still work over USB wifi ?
Thanks again.
There are currently 1985 users online. 2 members and 1983 guests.
