NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
Hi all this rom installed fine on my cx919 first time no problem at all
Originally posted by blinkone View Post
Originally posted by codger64 View PostHello - is your CX-919 the rk3188T chip model (mine says ver. 2.0 on the board)? I cannot get this ROM to work on mine? Did you change the kernel to the J22 kernel? I tried the: kernel_t_AP6210-J22_HD_v300.img and it won't boot into Android? Can you please let me know what you used exactly (flash tool, kernel, parameter, etc.) to get yours to work? Thanks.the standered kernel should work or you can try this rom below it worked perfect on mine v2.0 bored
in the rom below the instructions are noob frendly
Originally posted by blinkone View PostIf yours says v2.0 on the bored you are very lucky you have NOT got the t modelthe standered kernel should work or you can try this rom below it worked perfect on mine v2.0 bored
http://www.freaktab.com/showthread.p...nless-ROM-1-6b
I have tried the Finless Ver. 1.6 and it would show the Finless icon and start to boot but would never completly boot into Android?
Originally posted by zdns View Posthello can someone help me?
i have mini pc stick,the rom that install is: "RK3188_R-BOX_ANDROID4.2.2-SDK_V1.00_130514"
i want to upgrade so this rom is good for me?and if yes can someone plz tell me how i can do itPlease consider making a Donation to freakTab
Originally posted by zdns View Postthis is my devicePlease consider making a Donation to freakTab
Originally posted by zdns View Posthow can i know if it cx919 or cx919 II ?
there is a differnet ?Please consider making a Donation to freakTab
There are currently 4641 users online. 3 members and 4638 guests.
