NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
Originally posted by neomode View Post- Wifi
- Video Playback work´s without any Problem
- Rooted
What not Work ?
You tell me ;-)
Neomode
I flashed this rom on my MK809III (it seem to has AP6210 wifi module cause it works only with your fw). Wifi works well, full hd video is pretty smooth, everything is great except webcam.
I tried Logitech c510 and c615 cameras with different usb ports (via OTG cable and directly host port) with different applications such skype, camera, LINE camera and so on. In worse case app closes immediately, in best case it promts that can't connect to the camera.
MK809III connected to 2A power supplier.
Do you have any idea in what problem is? Is there any way to make it work with your firmware or may be you can point me on some other image?
I'll appreciate any help, thanks in advance!
I'm happy now =)
cant flashback from 1.9
NEO,
Interesting issue - I flashed 1.9 on my CX-919. working fine. But there was some issue with video playback. I wanted to flash BACK to 1.7. The Tool recognizes the Rock USB. However, when I try to flash 1.7, when I click erase IDB, it gets to RESET device, the device resets and take a little longer and the error message comes up "ERROR: wait for rock loader usb TIMEOUT " next line " ERROR: run failed"
I get the same error as above even if I do not click EraseIDB, and just click Run
But when I reflash 1.9, I do not get this error, it resets ok, and IMMEDIATELY reconnects and will flash 1.9.
I just tried to reflash with everything from 1.7, BUT I left the loader v2.07 in place. It resets device and reconnects and then proceeds to flash....BUT will not boot. stuck on boot cycle with RKMagic screen and android recovery..
I flashed 1.9 back and it flashes and boots ok....
Please help
Okay, so I downloaded the STOCK firmware from geekbuying and loaded it with RKbatchTOOL. It had loader ver 1.2x on there. It erased NAND and RESET okay, and downloaded the firmware okay (I think). I then went back to neomode 1.7 and clicked RUN. It installed fine and running fine!
Do you have explanation why this is the case?Bootloader 2.07 wont let reinstall bootloader 1.2x ?
very weird.
Bugs
Originally posted by baenaf1 View PostHi all!
Thanks for your great job!!!
I have the MK802IV 8Gb 2nd gen. with Neomode Hybrid ROM 1.7 flashed and it works very well, but I have got the same issue.
Randomly, the apps minimizes to desktop tray with no message.
Any idea for fixing?
Thanks in advance
mk809iii
hi there,
i just recieved my stick today and after 20 minutes of use :-D i had a bootloop. i flashed an another rom but wifi didn´t work. so i read many many hours.^^ now i just opend the case of the stick and i got the following informations from the platin:
Cyxtech RK3188 909 V 1.1 AP6210
I tried so much Roms today but Wifi didn´t work. Could anybody help me please to find the right ROM? :-D
Would be fine, because a new Stick and only 20 minutes fun ist pretty shitty
Regards
I have a big probleme with my cx919 and my tv.
With the original rom, i having no problem. But with this rom or the other rom, my tv not keeping the screen resolution 1280*720 50hz or 60hz. Every 1 or 2s my tv lost the signal, black screen! And immedialy the signal coming....
There are solution?
All rom dont work on my Tv, 1920*1080, 1280*720 and i have find only rom that ok 720*480. But it's very bad resolution. And i have a flickers 1 par minute....
I have flash my cx919 more than 20 times!
This night, i have find a rom, and all its ok. All resoltion is ok!
Its Android 4.4.beta firmware for tronsmart mk908ii,cx-919.
What is the problem with this rom and and other rom on my TV?
bad programming on the hdmi?
sorry for my bad english....
Hi, I've just installed this ROM on my MK802IV (new model).
Everything seems to work, but the screen flickers a lot, it's very annoying. Is this a known problem? (sorry I haven't read the whole thread). I've tried changing device screen resolution, changing hdmi port, rebooting... without success.
Thank you.
Edit: I have installed 1.9a version (I know it's not for mk802iv), and now everything is fineLast edited by woonaval; 10 January 2014, 17:08.
Cozyswan S400
Hi there people,
I've got a cozyswan s400(new wifi chip), will the 1.9 version work fine(any issues with wifi? how's performance compared to 1.7?) is there anyone with the same usb stick that tried 1.9?
I'm using currently 1.7 (I'm actually writting this from this stick which is connected to my pc monitor)
CX-919ii
I'm really confuses and lost about CX-919ii.
I got a lot of references for neomode roms but it doesn't look that there is a direct upgrade path.
I started another thread here http://www.freaktab.com/showthread.p...7-CX-919ii-J22 to get some level of isolation
There are currently 1365 users online. 1 members and 1364 guests.
