NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
Originally posted by neomode View PostHello,
Yes the Device is spoofed as Nexus 7 because the ROM is for more then one Device. So I make it like it is.
I include SuperUser because it is OpenSource App.
Neomode
Thanks Neomode for your fast reply and always help with all my requests!
What I really would like to know is wich of these two is better or is recommended by you to be use with this ROM 1.7?
Also would greatly appreciate if you could tell us something about the 1080 version of this ROM?... How good is the video playing?
Originally posted by poppillo View Postyes...twice
Here are a few things to try/consider.
Ensure your device is compatible with this ROM, it is only good for new newer devices. This can be checked by looking at the serial number on the sticker located on the reverse of the device. If it is 201307*** your good to go.
Because it is getting stuck at first boot/Initialization phase I might try re-downloading the Rom just to make sure its not corrupted a file some how and when unzipping use winrar its a decent application for decompressing files.
Make sure your in administrator mode while flashing.
Try a different USB cable.
It may take up to 5 minutes for the first boot to complete also I am unsure what the device would do if power was disconnected from the device during first boot.
I hope you get this sorted.
Good luck
Hi neomode
I flashed 1.7 rom and all good but if i start tincore keymaper ,which i use+ a lot with games, it just starts and after that closes
Sent from my GT-S7562 using Tapatalk now FreeFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Re: NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
Originally posted by neomode View PostMust see why that is so. Have you try to Update it over Play store. Because TinCore has release a new Version of it.
Neomode
Some little feedback about this ROM:
Video performance beats everything I've seen!
But in XBMC, using a tv streaming plugin for hours (even when not watching), the video gained A LOT of frame skipping. I don't know where to look for logs to help understand if this is a ROM issue or XBMC (13 Alpha8). Also yesterday I was watching "The Walking Dead" new episode (720p) and I've noticed some frame skipping too, but I didn't put the advancedsettings.xml on XBMC yet and will try that.
Also I would like to know what is the status of the 1080p version!Good work guys! Now I feel like the stick was worth the money!
AW: NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
Thank you. I make my ROM to make you all happy and have a good Device.
Try it with advance settings XML for xbmc. This should have you a better performer. Will hope I can finished Full HD today.
Ray aka Neomode
Originally posted by chopinko View PostThanks for this one!
How to flash this Rom via RECOVERY? Thats the only way im able to flash roms coz im having problems with my UG007b being recognized by PC.
Sent from my MI 2S using Tapatalk
Try the follow. Connect the Stick to HDMI and then press Reset Button and then Connect the USB Cable from PC to the OTG Port.
This should work.
Neomode
Originally posted by neomode View PostThank you. I make my ROM to make you all happy and have a good Device.
Ray aka Neomode
Gesendet von meinem GT-I9305 mit Tapatalk 2Can you tell me where to look for logs that can be useful? I want to know if this is a file related problem or XBMC. (BTW I've tried playing the file on MX Player with codec and the result was the same).
But don't let this get in the way of the 1080p version!And a million thanks for the work you put in this! Will donate as soon as possible!
There are currently 1617 users online. 3 members and 1614 guests.
