New firmware android 9.0 for Amlogic S905x
Yes, I remember bumerc rom, I could not go back to other rooms by using the usb burner because ports won't work, he gave me a power app with usb update function, so I guess the problem with the ports is recognition whether it's usb cable or flash usb, that is why I was hoping to search in the 4pda site. Thanks
Originally posted by sagert View PostIt looks like slimbox ported alex161rus recently.He wants to make an android 10 ATV for 1gb of memory.It is necessary to ask him a question about it and bumerc.
sagert just following up, still using alex161russ on mt T95M S905X, RTL8723, but today I wanted to try slimbox11.1, same rom I am using on my S912. Unfortunately I cant get the usb ports to work, will not read from the usb drive nor from the usb remote control transmitter. Otherwise the rom is excellent by slimbox, but do you know if its feasable to repair or port the usb (files) if any, from alex161russ, or from the stock rom, so that I can apply it to the slimbox rom, thanks a lot sagert.
Originally posted by minonano View Postsagert just following up, still using alex161russ on mt T95M S905X, RTL8723, but today I wanted to try slimbox11.1, same rom I am using on my S912. Unfortunately I cant get the usb ports to work, will not read from the usb drive nor from the usb remote control transmitter. Otherwise the rom is excellent by slimbox, but do you know if its feasable to repair or port the usb (files) if any, from alex161russ, or from the stock rom, so that I can apply it to the slimbox rom, thanks a lot sagert.
There are currently 2984 users online. 0 members and 2984 guests.
