New firmware android 9.0 for Amlogic S905x
    New firmware android 9.0 for Amlogic S905x.
    ​​​​​​Firmware address : https://mega.nz/#!b0cCSIYS!-9ML4Kocx...V_nIs7-UQ0KfeI
    I write English with translation. Therefore, I will be laconic. Write your feedback. I made this firmware as a port.
    This is an image from the firmware.
ID:	787785Click image for larger version
ID:	787786Click image for larger version
ID:	787787Click image for larger version
ID:	787788Click image for larger version
ID:	787789Click image for larger version
ID:	787790Click image for larger version
ID:	787791Click image for larger version
ID:	787792Click image for larger version
ID:	787793Click image for larger version
      The firmware should be flashed using USB Burning Tool v 2.1.7 .
        Does it has wifi/bluetooth support for Nexbox A95x model?
          Thank you sagert, Indeed perhaps you can confirm what wifi chipset is supported by your rom and the source from which you created your rom (superceleron and....).
            wifi 8189 for X96 works for me.It is necessary to test the second.Maybe ap6330.
              Superceleron for Khadas Vim1 and RUS-005 of 4pda.
                It is possible to root using Magisc 19.3.You need to update this file through Update&Backup.Then install Magisc Manager.
                  You may be able to add the required wifi drivers to the /vendor/etc/wifi folder after root permissions are installed.
                    Sounds pretty nice! My device is equipped with RT8189 bt combo...lets see...
                      There is an ATV 9 firmware: aml_upgrade_package-tx5-atv9-ap6212-1GB-2GB
                      DaivietPDA, guess it is APxx wifi chip?
                      Ill wait for the AML tools 7 from Ricky. Then I ll try - or maybe someone could assist - to take out wifi drivers from Sagert's (RT8189?) and put them in vendor's section of the ATV version: aml_upgrade_package-tx5-atv9-ap6212-1GB-2GB...hopefully it will work - would be awesome!!
                        Would this ROM have drivers for the WiFi chip in Mini M8SII or Tanix T5 Pro?
                          Maybe work for N5 Dual wifi??
                            This is in the /vendor/etc/wifi .Once root is installed , it's easy to make a folder here for other wifi drivers.If there are already 3 equivalent firmware then it is possible to change boot.img for wifi work.I do not know in detail how to add wifi drivers.
ID:	788034Click image for larger version
                              This in my terminal shows what modules work.
